| | #11 (permalink) |
| vista 64x | Re: pc monitor problems technosonic lcd tv LCD 1908 siemssen electronics uk ltd |
| | #12 (permalink) |
| vista 64x | Re: pc monitor problems was going well then green light on monitor flicked then came back on |
| | #13 (permalink) |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: pc monitor problems Sorry, but I don't think I'm going to be able to help any further with this one. I've been looking for a manual for your monitor, but have been unable to locate one. If you have one, I suggest that you read through it and see what it says about the monitor configuration for various source inputs, and the relative priority thereof. Depending on how it's configured, some sources will have a higher priority than others, and if a signal is received on such a source then the monitor will switch to that source (even if it's only a temporary switch). I'm only surmising though, I just wish I was able to locate a manual so that I could help you further. |
| | #14 (permalink) |
| Vista home premium 64 bit | Re: pc monitor problems Disconnect all sources apart from your computer and see if that works. |
| | #15 (permalink) |
| Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64 | Re: pc monitor problems It could also be an internal fault with the monitor. I had that once with a TV, where it wouldn't lock onto the SCART source, even when a signal was present (I did check the source with another TV, using the same cable, and no fault was found). I exchanged the TV for a new one (had only just got it), and it now works perfectly. |
| | #16 (permalink) |
| vista 64x | Re: pc monitor problems my mother board is a asrock 4coredual-sata2 with onboard grahics card nivida udate on microsoft yes i udated it then all my screen problems started deleted update screen not rebooted yet can this be sorted out or is there a problem or better update. |
| monitor resolution problems | Graphic cards | |||
| monitor problems | .NET General | |||
| 4 monitor problems | Vista General | |||
| monitor/screen problems | Vista performance & maintenance | |||
| New monitor and other problems | Vista hardware & devices | |||
