Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - pc monitor problems
Old 07-29-2009   #1 (permalink)
vista 64x
pc monitor problems
while useing my pc the channel changes to auto fm mono and i have to press pc button to get it back keeps happening nivida card monitor technosonic.
Old 07-29-2009   #2 (permalink)
Vista Ultimate x64 SP2
Re: pc monitor problems
Can you explain clearly?
Old 07-29-2009   #3 (permalink)
vista 64x
right when im useing my pc monitor it flicks of pc channel and comes back onto scart channel or another.
Old 07-29-2009   #4 (permalink)
Vista home premium 64 bit
Which monitor are you using?
Old 07-29-2009   #5 (permalink)
vista 64x
Old 07-29-2009   #6 (permalink)
vista 64x
when im useing monitor it goes from pc channel to another which says auto fm mono and i have to press pc button on control to get it back
Old 07-29-2009   #7 (permalink)
Vista Home Premium 32-bit & Vista Ultimate 64-bit both Service Pack 2 W7 Pro RTM 7600 32 & 64
Remove the SCART plug. One of the features of SCART is that of automatically switching a monitor/TV to that source if the device connected via that lead is powered on.
Old 07-29-2009   #8 (permalink)
vista 64x
removed scart from monitor all though scart is plug into my virgin box i never turn the virgin box on but i have took it out anyways lets see thanx for info
Old 07-29-2009   #9 (permalink)
vista 64x
removed scart still flicked over to auto fm mono
Old 07-29-2009   #10 (permalink)
What is the exact make and model number of your monitor? There should be a label stuck on the back of it with this information.
monitor resolution problems Graphic cards
monitor problems .NET General
4 monitor problems Vista General
monitor/screen problems Vista performance & maintenance
New monitor and other problems Vista hardware & devices
