| Vista Ultimate x64 SP2 | RivaTuner problem Hello, My dad got my brother a video card ( 9800gt ) and i told him to get rivatuner to change the fan speed. He did this and was playing his games for about a day, when he called me over and showed me his problem. He will bring up rt and change the speed but it goes back down to like 36% in a second. He has tried reinstalling and the problem was still there. Any help? |
| Vista Home Premium 64bit SP2 | Re: RivaTuner problem tell me exactly how he is using riva tuner to manage his fan speeds what version of riva tuner (linky) it is and what driver version (be thorough , dont skip over anything for example has he created any fan profiles?) and ill tell you what hes doing wrong........... |
| Vista Ultimate x64 SP2 | Re: RivaTuner problem Hello, there is a window he can go to and he can change is clock speeds, etc. and fan speeds. I told him just to change the fan speed and I believe he made two profiles, one he named games which is 70%, and one is normal (50%). He will then open up the window and click the profile he wants. Sorry if this isn't exact enough, but he isn't home right now, so I am doing this off the top of my head. |
| Vista Home Premium 64bit SP2 | Re: RivaTuner problem no mate tats fine but i need to know the version of riva tuner hes using and his current GPU driver version , Im asking becaus there is an incompatibility in the older version of riva with the newer drivers have a lok over this too it includes setting up fan profiles and temp controlled fan speed events RivaTuner generic guide - Guru3D.com Forums |
| Vista Ultimate x64 SP2 | Re: RivaTuner problem Sorry it's been so long, but I have been busy with school. Anyway, his driver version is 190.82, and his rivatuner is 2.24 |
| | #6 (permalink) |
| Windows Vista Enterprise x64 SP2 | Re: RivaTuner problem NVIDIA DRIVERS 191.07 WHQL You may want to go ahead and install that. Does your bios also control fan speed? |
| | #7 (permalink) |
| Vista Ultimate x64 SP2 | Re: RivaTuner problem I updated everything and the problem still occurs. I don't know if the bios controls it. How do I check? |
| | #8 (permalink) |
| Vista Home Premium 64bit SP2 | Re: RivaTuner problem its the version of riva tuner mate , it doesnt support those drivers , he has brought out an incrmental update 2.24c here (thats why i asked waht drivers and what version) RivaTuner v2.24c download from Guru3D.com the dev has been working on MSI afterburner ................ Introducing MSI Afterburner Overclock Software - Guru3D.com Forums a utility designed aroun riva tuner (worth getting before msi lock it out to their cards only) thats why he aint had time to update riva tuner recently he could also run his current version of riva tuner in driver emulation mode but its a pain in tha ass ![]() did you look through the guide i linked you too in my last post? |
| | #9 (permalink) |
| Vista Ultimate x64 SP2 | Re: RivaTuner problem He updated it to 2.24c and the problem is still there. |
| | #10 (permalink) |
| Windows Vista Enterprise x64 SP2 | Re: RivaTuner problem You will see a screen such as indicated below. You may want to change your settings to allow your RivaTuner to control fan. |
| RivaTuner | Software | |||
| RivaTuner v2.24 Update | Software | |||
| RivaTuner 2.23 | Software | |||
| New RivaTuner | Overclocking & Cooling | |||
| RivaTuner question | Graphic cards | |||
