8800GT 1GB alpha dog problem
gd0t
hey guys, heres the problem...
im running off the card now, its not detected inside my device manager tho...
if i try installing drivers the card isnt in the pc, or vista isnt 32bit... which it both is!!
this is EXTREMELY important to get done.. i have lots of coursework to do, in very little time. (2 days!!)
Right- here is my pc
Information and Instructions - IMEDIA X2416 - PB80146101 - iMedia - platform_amadeus_imedia - Desktop
Please help
i feel like im stuck in a dead end..i did try googling it. ;(
    Q8200
    1GB
    8800GT Alpha Dog 1GB
Please help
did you go to nvidia for the driver? look here GeForce 8 Series
good luck
ken
    Dell Inspiron E 1405
    [email protected]
    4 gigs
    integrated intel 945
    integrated
    300 gig internal
    10 down 1.5 up
ofc. i got the freshest ones. Last nights, and todays download to double check... plus before installtion.. i re-write over the files it unzips.. :/
    Q8200
    1GB
gd
you may have to boot into safe mode and install from ther but un-install the current driver first.
If you still cant we can go into device manager and delete it from there
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
tried installin in safe mode withotu drivers on pc.
it doesnt show up in device manager!
the only odd devices in thel ist with a little yellow triangle is
"PCI Express standard root port" and "SM Bus Controller"
any idea's?
    Q8200
    1GB
ok lets go into device manager
go to start>search>type device manager> look for display adapters
if yours is there and is working correctly fine. If it isn't there or if it has a yellow triangle on it the driver needs to be reinstalled. if it needs to be re-installed click on the adpter then click update driver and point it to where you have the new driver located
hope this helps
ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
display adapters isnt listed.. :/ but im running my screen off the card atm. even tho apparantly nothing is there and all that other yada!
    Q8200
    1GB
are you in safe mode? if so then you are running off a std vga display 800x600 resolution. if there aren't a display adapter listed then there is an "unknown" device with a yellow triangle that is probably youd video card. check that device and right click go to properties and see the details of the device. if it says its fdrom your vid card mfr then update driver there.
hope this helps
\ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
nope nothing like that.. im not runnin in safe mode either...
heres a pic in device manager of what i thinkg the gfx could possibly be...
this is the properties of the PCIe Standard.. etc with the little yellow triangle.
need to know anyother possible information about the system?
cheers again! i love the fast response! ;D
    Q8200
    1GB
gd
It might be but you need to look under the other tabs. In one of the tabs there is a long series of numbers and letters. with that you can google and find what that device is for
\ken
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
how do you know you are running off the card atm?
    [email protected]
    4 gigs
    integrated
    300 gig internal
    10 down 1.5 up
because im plugged into it and my screen is running off of it!!!
but in 800x600 - no advanced settings etc.
    Q8200
    1GB
1st thing i would do is uninstall that pci-e device then reboot, before windows loads id enter bios, normally by hitting DEL and check all the settings I.e pci-e enabled ect and also if you have on-board graphics you will need to disable it, save, exit and restart, all going well you should see a new device found bubble in the bottom right hand corner..... hope this helps you, Good luck
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    Realtek 7.1 CH HD Audio
    1280x1024 + 1360x768
    150GB Raptor HDD
    500GB Caviar HDD
    Thermaltake W0133RB 1200W PSU
    Antec 900
    Stock + Antec 900 case fans
    Logitech G15 (full layout)
    Logitech MX Revolution
thats what i thought, but theres nothing in the bios, look at link i provided.. screenshots of the bios is on there!
    Q8200
    1GB
your pcie slot is inactive , thats why your card isnt being detected have you installed your mobo drivers?
    XFX 780i
    4GB OCZ PC2-8500C5 DDR2
    Gainward GTX260/216 SLI
    Creative X-FI Xtreme Gamer
    Dell UltraSharp 2209WA 22"
    OCZ Modstream 700w
    Titan Fenir
    Razer Reclusa
    Logitech G5 Gamer
    8mb
Dude i see no Bios screen shot, Just device manager shots and those are 2 totally different things, anyway as a "process of elimination" have you connected the supplementary power connection form your PSU (power supply) to the 8800??
    Me :P
    Core 2 Quad Q6600
    Abit IN9 32X MAX
    150GB Raptor HDD
    500GB Caviar HDD
    Antec 900
you sure its all connected properly? perhaps its a defective card?
    Intel E2180 @ 3.0Ghz
    Gigabyte P35-DS3-L
    Patriot Extreme Performance 2GB 4-4-4-12
    EVGA 8800GT
    750 GB -Western Digital Caviar SE16 WD7500AAKS
    1 TB - Western Digital MyBook
