Go Back   Vista Forums > Vista Forums > Graphic cards
Vista - color red gone please help
Old 2 Weeks Ago   #1 (permalink)
Vista Home Premium 32bit
Was wondering if anyone can help me.
i have a NVIDIA GeForce 6150 LE and running Vista Pro 32
Its been 3 weeks i lost the color red. Mind you it came and went a few times. Also in the NVIDIA control panel i can adjust the other colors but red doesnt react. I have tried many drivers and still no fix.
Can anyone help?
Monitor is fine i have tried it on my other pc.
Thx
Old 2 Weeks Ago   #2 (permalink)
Vista 32 win 7 7600 32 bit
Re: color red gone please help
Quote  Quote: Originally Posted by Gman46 View Post
Can anyone help?
Thx
Gman
It feels like a hardware issue more than software. Might be a bent pin on the graphic card or cable or a loose wire on the card. Can you pull the graphic card and try it on another machine?
Ken J
Old 2 Weeks Ago   #3 (permalink)
I can't do that. I got a HP Pavilion Slimline which the card is on the motherboard. I tried removing and putting th cable back but didn't work. I guess i can still open up the PC and check it out. Strange thing is that a few days ago it went back to normal but only lasted a few minutes.
Old 2 Weeks Ago   #4 (permalink)
If it came back, I lean towards bad cable.
I say that as once the card goes bad, it isn't likely to recover.
Hmm... Have you tried different monitors ? Or checked the cable to the monitor ?
I have seen monitors go out more often than video cards, in my experience anyway.
edit:
On second thought. Its the cable or monitor. The pin on the cable supplying red could be it. Or the red color electronics in the monitor is bad.
Change monitors, and if that isn't it then try another video cable.
Old 2 Weeks Ago   #5 (permalink)
Not sure cause i connected the monitor with the same cable to my laptop and everything works fine. Only when i put it back on my pc this happenes. I thought it would be the drivers being faulty with vista.
thx for helping
Old 2 Weeks Ago   #6 (permalink)
Vista Ultimate x64
are you solved or u need more help?
Old 2 Weeks Ago   #7 (permalink)
no still going crazy. I wish there was a way i can test the grafic card. Makes no sense to me cause in the control panel i can adjust the other colors but the red doesnt even slide its as if its the software.
just nuts
Old 1 Week Ago   #8 (permalink)
Vista Ultimate 32-bit & Business 32-bit
Well, you've ruled out the monitor and the cable, and it's unlikely to be video drivers or setup -- unless you've been messing with the Gamma setting or the RGB mixes.
The most likely culprit is the video chipset in the HP. And, if that's true, the only fix will be an add-in card --which, if there is no room for expansion in the case, rules that out as well.
I'm guessing the unit has been out of warranty for a long time as well, right?
Old 1 Week Ago   #9 (permalink)
well this what i have done....
got a new video card and nothing doing. I checked out some motherboards and i got one that will match under $65CDN and a new tower Under $60CDN so gonna transfer everything over. Its not costing me much and now i can actually add to my pc which with a slimline u cant. Will post to see if it was my motherboard.
thxs
color value .NET General
Can't change Color of pages using color/appearance Vista installation & setup
off color Vista print fax & scan
Not all color names give right color? PowerShell
