Is this a graphics problem?
  1. #1
    Windows Vista Home Premium 32bit
    Local Time: 11:20 AM
    there are green spots everywhere on the screen and especially around the dark/black areas... can someone help me solve this problem?
  2. #2
    Yard Dog's Avatar
    Senior Member
    Central Florida in a small town
    Vista Home Basic. 32 bit SP 2
    Local Time: 11:20 PM
    usa us florida
    Re: Is this a graphics problem?
    Hello, have you checked drivers for graphics yet ? Can you hook up another monitor to check for monitor issues ?
  3. #3
      Thread Starter
    hmm... how do i do tt? i dun exactly have another monitor tt i can hook it up to... only laptops... but the display driver is okay for sure.. graphics driver, not so sure..
  4. #4
    Yard Dog's Avatar
    Senior Member
    usa us florida
    Look in Device Manager, which is located in your Control Panel, which you would see from the Start button, Open up Device manager and update/check Display Adapters.
  5. #5
      Thread Starter
    Nvidia Geforce GT 430. I have already updated it with the 285.62 update from the Nvidia website. So it should probably be alright.
  6. #6
    Yard Dog's Avatar
    Senior Member
    usa us florida
    That kinda makes it seem as if the monitor itself is failing.
  7. #7
      Thread Starter
    so its the monitor problem? or could it be the cable's problem?
  8. #8
    Yard Dog's Avatar
    Senior Member
    usa us florida
    Trouble shooting would have you use another known good cable to rule out cable . But, in my humble opinion, it would seem as if the monitor has bad hardware . Check out the cable first, of course.
  9. #9
      Thread Starter
    hahaz k thanks yard dog!
  10. #10
    Yard Dog's Avatar
    Senior Member
    usa us florida
    The most inexpensive way to solve an issue is of course to use known troubleshooting steps . The repair shop uses that method, thing is, they have bins of known good parts and they will swap out til the issue is solved, for the home user, our resources are , for the most part , limited . So, with that in mind, do what you can , before you have no choice but to take it to a Repair Shop. Good luck with this issue .
Page 1 of 2 12 LastLast
Is this a graphics problem? problems?
have problem with graphics perx Graphic cards 2 18 Oct 2009
Graphics problem or not? nate42nd Graphic cards 8 01 Feb 2009
Graphics Problem throbinson Graphic cards 23 25 Jan 2009
graphics problem DJ Vista hardware & devices 3 07 Feb 2007
graphics problem Rob Vista Games 2 01 Feb 2007
