Problems...
  1. #1
    Newbie
    Local Time: 05:05 AM
    Problems...
    hi, i dont totally know whats going on here, so please bear with me. I have a graphics card that should support AERO, but for some reason, windows vista home premium thinks i dont. i can not use windows movie maker, which i used to be able to use when i was running XP on this computer, nor can i take advandage of the AERO glass themes or thumbnails in the taskbar. How do i enable my graphics card so i can do all this?
    thanks,
    -ajp
  2. #2
    64bits's Avatar
    Knowledgeable
    Vista x64 Ultimate SP1___XP Pro x86 SP3
    Local Time: 11:05 AM
    uk
    Some more specs would help us to help you.
    What graphics card it is, which drivers your using etc, etc.
  3. #3
    Newbie
    Sweden
    Vista Ultimate x64
    Test installing the latest drivers for your card, the Vista installs doesn't work well...
  4. #4
    Junior Member
    Local Time: 02:05 AM
    Vista won't enable Aero unless your system scores high enough in the Windows Experience Index.
    After you install updated video card drivers, refresh your Windows Experience Index by doing the following:
    Start Orb -> type "Performance Information and Tools" into the search/run box and hit enter -> Click "Refresh Now" to refresh your score.
Problems...
Problems with new Logitech S-150 speakers problems with x64 vista infinitezero8 Sound & Audio 2 30 Aug 2009
Big vista problems need help icon/background/graphics/personalise problems cmdo83 Vista performance & maintenance 4 29 Jun 2009
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 qa4ever Vista General 2 09 Oct 2008
2 different vista problems. Memory dump crash and startup repair cannot fix problems Hiera Vista General 4 28 Jun 2008
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Chris Lane Vista installation & setup 1 13 Oct 2007
