Go Back   Vista Forums > Windows Live > Live Folder Share
Vista - This will fix your problems!!!!
Old 12-17-2007   #1 (permalink)
AlexData
Simply DELETE all your Libraries/Shares on www.foldershare.com
and make new one's.. This will probably fix it!
If it doesnt, try to make sure that each folder you share is within 2gb size
and a max of 5000 files (or 10.000 files)... test both choices...
If neither of these steps works, then maybe it is a firewall/router issue...
So to checkthat, turn off your windows firewall
(not recommended to keep it off, this is only for testing...)
And also turn off the firewall in your router (d-link or whatever brand)
if you have DMZ support on your router, enable that for the IP that goes to
the computer that you want to sync (do this on both ends, ex: at home, and at
work)
Then restart the machines (or restart foldershare) and see if it starts
sharing...
Also you could make a TEST-SHARE folder, with like 5 or 10 pictures in it
and share that on your pc's, to see it foldershare can handle that...
If none of these steps works, then post a notice about your problem, and
your computer setup in here.. (type of computer, router, firewalls used...)
Thanks for reading, and hope you'll succedd!!
Big vista problems need help icon/background/graphics/personalise problems Vista performance & maintenance
laptop start up problems and problems in general General Discussion
Problems starting command prompt on cygwin on vista ultimate, problems not had on Win2k3SP2 Vista General
2 different vista problems. Memory dump crash and startup repair cannot fix problems Vista General
Downgrading from 64bit Vista to 32bit, Media Center problems, web page printing problems Vista installation & setup
