| | speed problem (transfer rate) Hi, I'm new to FolderShare, but this is a very good tool. Everything is fine, but I'v serious problem with speed. I'm wanted to sync with 2 PC-s over internet. My transfer rate is 70-80 kB/s avg. Whats the problem? With FTP I can download with 500 kB/s from the same PC. I'm searching for this problem, but only find persons with the same problem, not found any solution. Please help, thanks, M. |
| | RE: speed problem (transfer rate) Hi if you are synching files then one PC is uploading and the other PC is downloading. If you are on ADSL then your upload bandwidth is likely to be much less than your download bandwidth. Hence that will limit the speed with which you can sync these files. "Mikka" wrote: Quote: > Hi, > > I'm new to FolderShare, but this is a very good tool. Everything is fine, > but I'v serious problem with speed. I'm wanted to sync with 2 PC-s over > internet. My transfer rate is 70-80 kB/s avg. Whats the problem? With FTP I > can download with 500 kB/s from the same PC. I'm searching for this problem, > but only find persons with the same problem, not found any solution. > > Please help, > thanks, > > M. |
| | RE: speed problem (transfer rate) Thank You for your reply. Im, wanted to sync from a 100Mbit server so not this is the problem. (with FTP works 500+ kB/s). In the other end I'm using ADSL (for download). M. "mart" wrote: Quote: > Hi > > if you are synching files then one PC is uploading and the other PC is > downloading. If you are on ADSL then your upload bandwidth is likely to be > much less than your download bandwidth. Hence that will limit the speed with > which you can sync these files. > > "Mikka" wrote: > Quote: > > Hi, > > > > I'm new to FolderShare, but this is a very good tool. Everything is fine, > > but I'v serious problem with speed. I'm wanted to sync with 2 PC-s over > > internet. My transfer rate is 70-80 kB/s avg. Whats the problem? With FTP I > > can download with 500 kB/s from the same PC. I'm searching for this problem, > > but only find persons with the same problem, not found any solution. > > > > Please help, > > thanks, > > > > M. |
| | Re: speed problem (transfer rate) Mikka wrote: Quote: > Im, wanted to sync from a 100Mbit server so not this is the problem. (with > FTP works 500+ kB/s). In the other end I'm using ADSL (for download). between Kb/s and KB/s. 70 KB/s is about 700 Kb/s. richi. www.richij.com |
| Slow USB Transfer Rate. | Vista performance & maintenance | |||
| Transfer rate | Vista networking & sharing | |||
| Extremely low transfer rate from my DVD | Vista performance & maintenance | |||
