1.    16 Sep 2009 #1
    Porrotu Guest
    One or more parts of this message could not be displayed
    Sometimes, my inbox items will not display in the preview pane.
    When i double click to open it, an information pop-up comes saying:
    "One or more parts of this message could not be displayed." [OK]
    After i click ok, an error pop-up window comes up:
    "There was an error opening this message.
    An error has occured." [OK]
    Then it comes back to the folder.
    If i try to reply to any of those messages, the same messages will appear.
    What is wrong?
  2.    16 Sep 2009 #2
    Michael Santovec Guest
    Re: One or more parts of this message could not be displayed
    What kind of mail account is it? POP3, IMAP or HTTP?
    If you right click on the message in the message list and select
    properties what happens?
    Mike - http://TechHelp.Santovec.us
    "Porrotu" <Porrotu@newsgroup> wrote in message
    news:2C8542C4-24D7-43A6-9006-4808827C651C@newsgroup
    > Hi,
    > appear.
    > What is wrong?
  3.    17 Sep 2009 #3
    Porrotu Guest
    It's my MSN account. So i think now works as a POP3.
    > > Hi,
    > > appear.
    > > What is wrong?
  4.    17 Sep 2009 #4
    Not necessarily. WLM still supports HTTP. Outlook Express would have
    to use POP3.
    Look in Tools, Accounts, Mail, Properties, Servers. It will tell you
    the server type.
    news:57378DAB-28E6-453D-98D6-D05B6CD845F6@newsgroup
    >> > Hi,
    >> > appear.
    >> > What is wrong?
  5.    17 Sep 2009 #5
    Porrotu Guest
    I thought we were in a section of the discussions dedicated only to WLM.
    I think those instructions (starting in Tools, etc) relate only to Outlook.
    I did, however, right click on my folder header for my MSN account, click on
    properties and found under the Server tab:
    My mail server is an HTTP server
    http://oe.msn.msnmail.hotmail.com/cgi-bin/hmdata
    Does that help?
    > to use POP3.
    > the server type.
    > >> > Hi,
    > >> > appear.
    > >> > What is wrong?
  6.    17 Sep 2009 #6
    The Tools, Accounts, Mail, etc. applies to many mail clients including
    WLM, Outlook Express, Vista Windows Mail, etc.
    If you look at the problem messages using he web interface does it have
    the same problem?
    news:5F4DB716-54EC-4CBB-B634-03DDB68A62FC@newsgroup
    > WLM.
    > Outlook.
    > click on
    > Does that help?
    >> have
    >> to use POP3.
    >> the server type.
    >> >> > Hi,
    >> >> > saying:
    >> >> > [OK]
    >> >> > will
    >> >> > appear.
    >> >> > What is wrong?
  7.    17 Sep 2009 #7
    Ron Sommer Guest
    I was browsing the Outlook newsgroup and read that when Outlook is setup to
    use pop3 the tab will say Servers and when it is setup for http, it will say
    Server. Does that also apply to OE?
    Ron Sommer
    MVP-Mail
    "Michael Santovec" <michael_santovec@newsgroup> wrote in message
    news:OXH7vQ7NKHA.5128@newsgroup
    > Not necessarily. WLM still supports HTTP. Outlook Express would have to
    > use POP3.
    > Look in Tools, Accounts, Mail, Properties, Servers. It will tell you the
    > server type.
    >>> > Hi,
    >>> > appear.
    >>> > What is wrong?
  8.    17 Sep 2009 #8
    Porrotu Guest
    No, if i open IE to see my e-mail, I can immediatelly see it in the Preview
    Pane.
    I think i found the cause: Cisco Clean Agent is blocking some wlmail.exe to
    execute. Kinda random, cuz sometimes i can see them, some dont.
    My problem now is that I cant find where to set Cisco to allow wlmail.exe to
    work.
    Anyone knows about Cisco Clean Agent??
    (for my own knowledge, Where is the TOOLS menu in WLM? I cant find it)
    > the same problem?
    > > WLM.
    > > Outlook.
    > > click on
    > > Does that help?
    > >> have
    > >> to use POP3.
    > >> the server type.
    > >> >> > Hi,
    > >> >> > saying:
    > >> >> > [OK]
    > >> >> > will
    > >> >> > appear.
    > >> >> > What is wrong?
  9.    18 Sep 2009 #9
    Ron Sommer Guest
    Alt + M, M
    Ron Sommer
    MVP-Mail
    news:EC842E5A-4629-4A1F-9D51-F01B2AB9F73D@newsgroup
    > Preview
    > Pane.
    > to
    > to
    > work.
    >> the same problem?
    >> > WLM.
    >> > Outlook.
    >> > click on
    >> > Does that help?
    >> >> have
    >> >> to use POP3.
    >> >> the server type.
    >> >> >> > Hi,
    >> >> >> > saying:
    >> >> >> > [OK]
    >> >> >> > will
    >> >> >> > appear.
    >> >> >> > What is wrong?
  10.    18 Sep 2009 #10
    Porrotu Guest
    Thanks!!
    "Ron Sommer" wrote:
    > Alt + M, M
    > Ron Sommer
    > MVP-Mail
    > > Preview
    > > Pane.
    > > to
    > > to
    > > work.
    > >> the same problem?
    > >> > WLM.
    > >> > Outlook.
    > >> > click on
    > >> > Does that help?
    > >> >> have
    > >> >> to use POP3.
    > >> >> the server type.
    > >> >> >> > Hi,
    > >> >> >> > saying:
    > >> >> >> > [OK]
    > >> >> >> > will
    > >> >> >> > appear.
    > >> >> >> > What is wrong?
Message Could Not be Displayed
This message has been stucked in the viewing window for over a week. It also continues to appear as Unreade-mail (1). I have even attempted a...
Live Mail
message could not be displayed?????
I have just installed wl mail and the title of the email is dowloaded, however the actual email does not download. the reading pane shows'' message...
Live Mail
Message could not be displayed
I received 3 emails with this message. I can't delete them or move them. They are junk and I would like to get rid of them. What do I need to do?...
Vista mail
I recently moved to Qatar and I haven't been able to get Windows Live Mail to work properly. I can download the message headers but the contents...
Live Mail
message can't be displayed - can't delete message from inbox
I have a message in my inbox that comes up with 'message can not be displayed' so I want to delete it from my inbox, but then I get that 'an...
Vista mail
RE: Message could not be displayed
Hi, can anyone help me with this? I just recently upgraded from Windows Live Mail Desktop to Windows Live Mail. THe problem is that I cannot read...
Live Mail
Message not displayed
" Message could not be displayed Windows Mail encountered an unexpected problem while displaying this message. Check your computer for low memory...
Vista mail
Our Sites
  • Ten Forums
  • Eight Forums
  • Seven Forums
  • PC Help Forum
  • Help Me Bake
  • Site Links
  • Contact Us
  • Privacy and Cookies
  • About Us
    Windows Vista Forums is an independent web site and has not been authorized, sponsored, or otherwise approved by Microsoft Corporation. "Windows 10" and related materials are trademarks of Microsoft Corp.
    Designer Media Ltd
