Go Back   Vista Forums > Windows Live > Live Messenger
Vista - Contacts Group Sync problem with Visa
Old 03-29-2008   #1 (permalink)
Ryan Zhang
hi guys,
I got a Sync issue with WLM contacts Group.
The thing is,once you take the Live contacts Encrypt From the WLM
(Option-Security-Encrypt contact list data so that it is not accessible
outside of Windows Live Messenger), you will be able to access it from
C:\Users\Administrator\Contacts\Your E-mail Account
Then there is some File with suffix .Group, when you click to open it. those
files contain no info as Grouped contacts. it just Blank.
When you add some new contacts into that Group. it will not be updated into
WLM List. so as the Hotmail Live Contacts.
However, When you delete the .Group file, it will be resored while next time
you log in WLM. and when you creat a new .Group File, it will be take updated
into WLM contacts list. But again, any info in the windows contact Group will
not be Upload.
Please advice the Fix for that. Thank you all.
Old 03-29-2008   #2 (permalink)
Ryan Zhang
RE: Contacts Group Sync problem with Visa
Aslo, the Other problems is, the local .Contact files doesn't contain the
"IM E-mail address", which would be helpful as most people use then as E-mail
account.
"Ryan Zhang" wrote:
Quote:
> hi guys,
> not be Upload.
group contacts only send to part of the group Vista mail
Contacts move from a specific group to "Other Contacts" group ? Live Messenger
Contacts moving from group to group randomly. why? Live Messenger
Sync contacts - Nokia phone with Windows Contacts Vista mail
Sync Outlook 2007 Contacts with Windows Contacts Vista mail
