br> br> |
| | Thread Tools | Display Modes |
| Guest | ElevationPolicy problem Hi. Live Messenger cannot finished initialize some thing after vista update sp1 or IE MS08-024 patch. It want to modify reg key as {D133B285-8A43-4EC7-9B909C2370F5}. I cannot modify or remove this key. I also try to remove Live Messenger, but failed too. Have somebody known how to fix it. Thanks |
| Guest | RE: Changing email provider in messenger Hi I have just installed messenger & if I want to keep informed of my email messages from yahoo, I would click the email icon. When I click the email incon I brings up my inbox for my internet provider. How do I change it to yahoo? |
| | #3 (permalink) | ||||||||||||
| Guest | Re: Changing email provider in messenger Greetings Daniel, If you use something other than a @hotmail, @msn or @live Windows Live ID, then Messenger will take you to your default e-mail program (well, and if you're not signed into the Live Mail application with the same ID, or it will go there). To set that program, you can go to Internet Explorer, then Tools, then Internet Options and then the Programs tab. Depending on what version of Windows you're using, you may need to explore that tab a little. -- Jonathan Kay Microsoft MVP - Windows Live Messenger MSN Messenger/Windows Messenger MessengerGeek Blog: http://www.messengergeek.com Messenger Resources: http://messenger.jonathankay.com (c) 2008 Jonathan Kay - If redistributing, you must include this signature or citation -- "Daniel" <Daniel @discussions.microsoft.com> wrote in message news:3C38A1C2-8F34-4ED2-973B-5C98BD28C9CB@xxxxxx
My System Specs![]() | |||||||||||||
| Display Modes | |
| Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! | Jim Hansen | Vista General | 3 | 12-16-2007 08:09 PM |
| Generic McAfee Problem Message in Vista Problem Reports | cyberbuff53 | Vista performance & maintenance | 0 | 12-01-2007 07:55 AM |
| fixed unable to delete email problem, now I have new problem | j2 | Vista mail | 19 | 03-29-2007 08:25 PM |
| audio problem with my sony vaio laptop and x64 problem | =?Utf-8?B?YWxleA==?= | Vista hardware & devices | 1 | 07-14-2006 09:32 AM |
| Vista Upgrade Problem - Windows Explorer Loop problem | Steve S | Vista installation & setup | 0 | 06-27-2006 10:15 AM |
