hi,
I got exactly the same problem before!
what you can try is: click on alt - tools - options - connection.
there is the status of the connection. it should say something like:
you are connected to the internet via Upnp. When it says something
like: it is not Upnp, then you have to figure out how to enable Upnp in
your router/modem
Second thing was: i connected a Usb1.1 webcam to a Usb2.0 pci card. (Should
be no problem however people could not understand what i say.) Adding an
Usb2.0 cam and the problem was solved.
heian
----- Original Message -----
Newsgroups: microsoft.public.windows.live.messenger
Sent: Tuesday, May 27, 2008 8:40 AM
Subject: Audio issue
i'm getting a clicking sound on my windows live messenger and video quality
is jumping. Using broadband service here in kuwait WLM was working fine
before i changed to faster service now i have jumping picture and a constant
clicking for audio
