| | Problem - typed message not visible in conversation window I have a friend who is having a problem with his Conversation Window. When he is typing in a message to send, it does not appear visible in the window and he cannot see what he is typing. However, when he hits enter key or or clicks send, the message appears but is also then sent. Have looked at fonts, backgrounds, etc, but all appears normal. Have also "repaired" via the Add & Remove Programs in Control Panel, but this has not solved the problem either. Any ideas on how to solve the problem |
| | RE: Problem - typed message not visible in conversation window We are having the same problem. I have also looked at the fonts and have done the "repair" but still now luck. We even removed the program and reinstalled it. The handwriting feature and the emoticon's work. We can see both of those but no text. For what its worth, I am glad to see someone else is also having this problem. I saw somewhere, on a blog, that it was a "bug" and MS was aware of it but I dont remember where the blog was. I know it was in Live Messenger support but no luck locating it again. "Josh" wrote: Quote: > I have a friend who is having a problem with his Conversation Window. When he > is typing in a message to send, it does not appear visible in the window and > he cannot see what he is typing. However, when he hits enter key or or clicks > send, the message appears but is also then sent. Have looked at fonts, > backgrounds, etc, but all appears normal. Have also "repaired" via the Add & > Remove Programs in Control Panel, but this has not solved the problem either. > Any ideas on how to solve the problem |
| | RE: Problem - typed message not visible in conversation window Thanks, like you am pleased to know someone else has the problem. Haven't found a solution yet, but if we do will let you know. "micumedic" wrote: Quote: > We are having the same problem. I have also looked at the fonts and have done > the "repair" but still now luck. We even removed the program and reinstalled > it. The handwriting feature and the emoticon's work. We can see both of those > but no text. For what its worth, I am glad to see someone else is also having > this problem. I saw somewhere, on a blog, that it was a "bug" and MS was > aware of it but I dont remember where the blog was. I know it was in Live > Messenger support but no luck locating it again. > > "Josh" wrote: > Quote: > > I have a friend who is having a problem with his Conversation Window. When he > > is typing in a message to send, it does not appear visible in the window and > > he cannot see what he is typing. However, when he hits enter key or or clicks > > send, the message appears but is also then sent. Have looked at fonts, > > backgrounds, etc, but all appears normal. Have also "repaired" via the Add & > > Remove Programs in Control Panel, but this has not solved the problem either. > > Any ideas on how to solve the problem |
| | RE: Problem - typed message not visible in conversation window Ok, found the web address for the blog entry from MS. http://messengersays.spaces.live.com/ check it out. I wish they would get it fixed. My friend has to go into her "view message history" to read her IM's. A pain in the !@#. "Josh" wrote: Quote: > Thanks, like you am pleased to know someone else has the problem. Haven't > found a solution yet, but if we do will let you know. > > "micumedic" wrote: > Quote: > > We are having the same problem. I have also looked at the fonts and have done > > the "repair" but still now luck. We even removed the program and reinstalled > > it. The handwriting feature and the emoticon's work. We can see both of those > > but no text. For what its worth, I am glad to see someone else is also having > > this problem. I saw somewhere, on a blog, that it was a "bug" and MS was > > aware of it but I dont remember where the blog was. I know it was in Live > > Messenger support but no luck locating it again. > > > > "Josh" wrote: > > Quote: > > > I have a friend who is having a problem with his Conversation Window. When he > > > is typing in a message to send, it does not appear visible in the window and > > > he cannot see what he is typing. However, when he hits enter key or or clicks > > > send, the message appears but is also then sent. Have looked at fonts, > > > backgrounds, etc, but all appears normal. Have also "repaired" via the Add & > > > Remove Programs in Control Panel, but this has not solved the problem either. > > > Any ideas on how to solve the problem |
| | RE: Problem - typed message not visible in conversation window Thanks for the advice. Same scenario. Hope it is sorted soon, cos it's a pain. "micumedic" wrote: Quote: > Ok, found the web address for the blog entry from MS. > http://messengersays.spaces.live.com/ check it out. I wish they would get it > fixed. My friend has to go into her "view message history" to read her IM's. > A pain in the > !@#. > > "Josh" wrote: > Quote: > > Thanks, like you am pleased to know someone else has the problem. Haven't > > found a solution yet, but if we do will let you know. > > > > "micumedic" wrote: > > Quote: > > > We are having the same problem. I have also looked at the fonts and have done > > > the "repair" but still now luck. We even removed the program and reinstalled > > > it. The handwriting feature and the emoticon's work. We can see both of those > > > but no text. For what its worth, I am glad to see someone else is also having > > > this problem. I saw somewhere, on a blog, that it was a "bug" and MS was > > > aware of it but I dont remember where the blog was. I know it was in Live > > > Messenger support but no luck locating it again. > > > > > > "Josh" wrote: > > > > > > > I have a friend who is having a problem with his Conversation Window. When he > > > > is typing in a message to send, it does not appear visible in the window and > > > > he cannot see what he is typing. However, when he hits enter key or or clicks > > > > send, the message appears but is also then sent. Have looked at fonts, > > > > backgrounds, etc, but all appears normal. Have also "repaired" via the Add & > > > > Remove Programs in Control Panel, but this has not solved the problem either. > > > > Any ideas on how to solve the problem |
| | #6 (permalink) |
| | Re: Problem - typed message not visible in conversation window Does this issue still exist after upgrading to the latest Windows Live Messenger Beta? http://download.live.com - Jeroen [MSFT] "Josh" <Josh@xxxxxx> wrote in message news:CDA85BE0-66A8-4FC6-8CEA-9B9EF325717E@xxxxxx Quote: > Thanks for the advice. Same scenario. Hope it is sorted soon, cos it's a > pain. > > "micumedic" wrote: > Quote: >> Ok, found the web address for the blog entry from MS. >> http://messengersays.spaces.live.com/ check it out. I wish they would get >> it >> fixed. My friend has to go into her "view message history" to read her >> IM's. >> A pain in the >> !@#. >> >> "Josh" wrote: >> Quote: >> > Thanks, like you am pleased to know someone else has the problem. >> > Haven't >> > found a solution yet, but if we do will let you know. >> > >> > "micumedic" wrote: >> > >> > > We are having the same problem. I have also looked at the fonts and >> > > have done >> > > the "repair" but still now luck. We even removed the program and >> > > reinstalled >> > > it. The handwriting feature and the emoticon's work. We can see both >> > > of those >> > > but no text. For what its worth, I am glad to see someone else is >> > > also having >> > > this problem. I saw somewhere, on a blog, that it was a "bug" and MS >> > > was >> > > aware of it but I dont remember where the blog was. I know it was in >> > > Live >> > > Messenger support but no luck locating it again. >> > > >> > > "Josh" wrote: >> > > >> > > > I have a friend who is having a problem with his Conversation >> > > > Window. When he >> > > > is typing in a message to send, it does not appear visible in the >> > > > window and >> > > > he cannot see what he is typing. However, when he hits enter key or >> > > > or clicks >> > > > send, the message appears but is also then sent. Have looked at >> > > > fonts, >> > > > backgrounds, etc, but all appears normal. Have also "repaired" via >> > > > the Add & >> > > > Remove Programs in Control Panel, but this has not solved the >> > > > problem either. >> > > > Any ideas on how to solve the problem |
| WLM9 14.0.5027.908 crash after I try to open conversation window | Live Messenger | |||
| Conversation window does not follow default colour specified | Live Messenger | |||
| Conversation window can't display user's name if Non-English is us | Live Messenger | |||
| Mysterios Office Image in conversation window | Live Messenger | |||
| typed message disappears | Vista mail | |||
