Go Back   Vista Forums > Windows Live > Live Messenger
Vista - "Click-to-call BHO" breaks Xbox forums
Old 11-10-2008   #1 (permalink)
Schief
After installing the Messenger Beta, I am unable to use IE to browse the Xbox
forums at www.xbox.com.
I realized it was not something Xbox.com changed as all the other browsers
continued working fine. I finally went into IE and started disabling add-ons
one by one until I found the culprit: "Click-to-call BHO". After disabling
it, the site would once again load just fine.
Try this out yourself by going to "www.xbox.com" and click on "forums" in
the header. IE will lock solid for 3+ minutes or longer. Disable
Click-to-call BHO and try again and you will see it render like FireFox,
Safari, and Chrome.
Is someone aware of this?
"right click" and "open" on an icon does not start the program! Vista General
Error on return from function call in ASP.NET "Operation is not supported on this platform." .NET General
CoD 4 is "Preparing to launch Call of Duty 4: Modern Warfare..." FOREVER! Gaming
CMAK "remove_gateway" in Vista Breaks VPN Vista networking & sharing
Explorer, "Browse" just breaks and crashes out Vista file management
