| | Messenger and Kiwee problem Hi All, Using Messenger version: 2008 build: 8.5 1302 1018 I have Kiwee attached to that window on the left when I need to type to somebody. I think that may cause me that problem. I don't have the Kiwee toolbar but those icons stuck to the Messenger window and under Un Install I can't find anything about it. How to remove that Kiwee from the Messenger? Or I could remove the messenger completely and remove all references in the registry Using Vista Ultimate 64 bits Any idea? Thanks, Eric |
| Kiwee problems on messenger 8.1 | Windows Live | |||
| Re: msn messenger problem | Live Messenger | |||
| Problem with messenger 8.5 crashing | Live Messenger | |||
| Yahoo Messenger problem | Sound & Audio | |||
| UPNP and Messenger problem | Vista networking & sharing | |||
