Go Back   Vista Forums > Windows Live > Live Messenger
Vista Tutorial - WLM 2009 Build 14.0.8050.12.02 Problem
Old 12-17-2008   #1 (permalink)
Henry Fitzroy
Guest
Well i hope it is still Beta cause there is a problem with coloring chat
window..
You can select screen as 5027 version but it doesnt change the color as
before now.. and when you apply the background it just applies to small part
of the screen which your and the other persons msges are shown.. it would be
better as before in the 5027 to apply it to whole screen.. o
Old 12-19-2008   #2 (permalink)
ups
Guest
RE: WLM 2009 Build 14.0.8050.12.02 Problem
I second this post.
Coloring the windows has become somewhat sketchy. I don't like fancy
pictures but there isn't a nice scene for simple coloring (Even the standard
one has some weird lines).
Also, the conversation window no longer has the scene picker. Also it not
always follows the main window scene as well.
Also, The notifications popup alert, no longer follows the color scheme of
the main window.
"Henry Fitzroy" wrote:
> window..
WLM 2009 (Build 14.0.8050.12020 Live Messenger
Build 14.0.8050.1212 Quick View Live Mail
Error 8000401a - Windows Live Messenger 2009 (14.0.8050.1202) Live Messenger
Major Issue Regarding Windows Live Messenger build 14.0.8050.1202! Live Messenger
What happened to Signature Sounds on the newest 2009 build 14.0.8050.1202? Live Messenger
