Go Back   Vista Forums > Windows Live > Live Messenger
Vista - Emoticons problem
Old 01-01-2009   #1 (permalink)
Vista Home Premium 32bit
Emoticons problem
My friend tries to send me custom emoticons, but I can't add them...no one can add them from her, it only says "copy" when we right click...any way to fix it? (she wants to able to let others add them btw)
Old 01-02-2009   #2 (permalink)
Jonathan Kay [MVP]
Re: Emoticons problem
Greetings Fawa,
As a first test to just narrow down the problem, have her add any random image as an emoticon
(like a Picture off the web or in her Pictures folder) then have her send the emoticon to you
on Messenger and see if you can add that one.
If you can, then it's just that her old emoticons in Messenger have the "premium" flag set.
Although I'll have to double-check to see if there's any other way to remove the premium
flag, this might mean that she'll need to readd all the emoticons manually which won't be too
difficult but will be time consuming.
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation
"fawa" <guest@xxxxxx-email.com> wrote in message
news:048dbc6689c9f826468d32588877dd46@xxxxxx-gateway.com...
> fawa
Old 08-03-2009   #3 (permalink)
TheCroW
Re: Emoticons problem <<WARNING>>
> Hi fawa, if you are looking for some emoticons, you can visit
Quote:
> 'SweetIM.com'
> They offer hundreds of emoticons which you can download for free and
> also share easily with your friends. Try it out!
> deazy86
Nice try ... ofcourse this is spam. SweetIM also shows up on several warning
sites as having ad- and malware, also browser exploit and so on. So do not
download this stuff!!
Menno
problem with loading contact pictures and custom emoticons Live Messenger
Problem with emoticons in WLM 09 Windows Live
Custom emoticons showing in Groups although disabled custom emoticons Live Messenger
cant sent all emoticons Live Messenger
Emoticons Vista mail
