| vista 32 | need help with messenger 9 can anyone help.. its prob so easy to fix.. but i can't work it out..lol i installed the latest version of messenger.. but for some reason i can't see what i am typing till after i have hit enter.. which is a real pain.. lots of spelling mistakes..lol i have tried changing background colour and font colour but no luck.. any help would be much appreciated.. thanks |
| | Re: need help with messenger 9 Greetings, As a start, you may want to check to see if the video device/card/chip installed in your PC has any driver updates. Although the best source for drivers is from the manufacturer, you can also use Windows Update to see if there are any updated drivers by just visiting Windows Update and looking through what is available for your system. -- Jonathan Kay Microsoft MVP - Windows Live Messenger MSN Messenger/Windows Messenger MessengerGeek Blog: http://www.messengergeek.com Messenger Resources: http://messenger.jonathankay.com (c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation -- "blackgypsy" <guest@xxxxxx-email.com> wrote in message news:c7a9aad4a996e9d122dfcbc20325540f@xxxxxx-gateway.com... Quote: > > can anyone help.. its prob so easy to fix.. but i can't work it out..lol > i installed the latest version of messenger.. but for some reason i > can't see what i am typing till after i have hit enter.. which is a real > pain.. lots of spelling mistakes..lol i have tried changing background > colour and font colour but no luck.. any help would be much > appreciated.. thanks > > > -- > blackgypsy |
| vista 32 | Re: need help with messenger 9 Thanks Jonothan.. i will give that a go and see if it helps... |
| Windows Live Messenger vs Yahoo messenger | Vista General | |||
| Windows Live Messenger vs Yahoo messenger | Live Messenger | |||
| I cannot login to MSN Messenger even E-buddy or MSN Web Messenger | Live Messenger | |||
| Trouble Downloading Windows Live Messenger and Microsoft Messenger | Live Messenger | |||
| Yahoo messenger and Windows Live Messenger wont connect on Vista | Vista installation & setup | |||
