Go Back   Vista Forums > Windows Live > Live Messenger
Vista - WLM 2009 Problem
Old 03-17-2009   #1 (permalink)
vista home basic 32bit
WLM 2009 Problem
Hi there,
I have been trying to update my messenger to the latest one but every time it downloads the neccessary files it cancels itself then rolls back the installation even though cancel was not pressed.
Has anyone else encountered this problem?
Old 03-17-2009   #2 (permalink)
Jonathan Kay [MVP]
Re: WLM 2009 Problem
Greetings,
It's encountering an error and then rolling back.
As an easy starting point, try manually installing Messenger by simply downloading and
running the MSI file:
http://messenger.jonathankay.com/redir/w3qfe/wlm.asp
If that installs without an error (it'll just install and disappear if it's successful), then
install the Communications Platform:
http://messenger.jonathankay.com/red...e/contacts.asp
If that installs correctly, you can now use Messenger by running it from the Start menu,
Windows Live folder. However, I suspect either of these will error out and will tell you
what the problem is. There's also an log generated by the installer, but just running these
is certainly easier than locating and parsing the log file.
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation
"DragonLee911" <guest@xxxxxx-email.com> wrote in message
news:ee77a637d88322b2ba5fd329bb462691@xxxxxx-gateway.com...
Quote:
> Hi there,
> DragonLee911
Old 03-20-2009   #3 (permalink)
Hi thanks for the fast reply, but you were right. It errored when i tried to install the Windows Live Commmunications Platform. it says its on a network resource that is unavailable. what does this mean?
Any known problem with 2009 (14.0.8064.206) Live Messenger
Problem on WLM 2009 Live Messenger
WLM 2009 Install Problem Live Messenger
Problem with WLM 2009 Beta Live Messenger
WLM 2009 Beta Problem - Webcam Live Messenger
