| 03-21-2009 | #1 (permalink) |
| | Problem with wink (chucks wink workshop) Hi, there seems to be a problem with the wink you can create at http://www.msnmessengerexperience.nl/chuck/wink/ I can create the wink but i can't install it ! a message pops up "not al content could be installed, try again later" But i tried it on different computers, all gave the same pop-up. All the computers i tested had windows live messenger 2009 (latest). a few months ago it all worked fine ?! (with the old messenger). |
| My System Specs |
| 03-21-2009 | #2 (permalink) |
| | Re: Problem with wink (chucks wink workshop) Greetings Maurice, I tried it here using the previous version of Messenger and got the same message. I also checked to see where it gets the content and it does appear to be being redirected (although the content is still there). It doesn't appear to actually download the content though. It might be possible to hack something together to make it work, but for now though it is broken, regardless of what version you're using. -- Jonathan Kay Microsoft MVP - Windows Live Messenger MSN Messenger/Windows Messenger MessengerGeek Blog: http://www.messengergeek.com Messenger Resources: http://messenger.jonathankay.com (c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation -- "Maurice Konings" <MauriceKonings@xxxxxx> wrote in message news:27F8154A-04EA-4FEB-88BC-66699B7E09D4@xxxxxx Quote: > Hi, there seems to be a problem with the wink you can create at > http://www.msnmessengerexperience.nl/chuck/wink/ > > I can create the wink but i can't install it ! a message pops up "not al > content could be installed, try again later" But i tried it on different > computers, all gave the same pop-up. All the computers i tested had windows > live messenger 2009 (latest). a few months ago it all worked fine ?! (with > the old messenger). |
| My System Specs |
| Similar topics to: Problem with wink (chucks wink workshop) | ||||
| send a wink or nudge option greyed out | Live Messenger | |||
| Greetings Workshop with Vista | Software | |||
| Greetings Workshop and Vista | Vista General | |||
| Can not open Excel workshop in email attachment even after saving. | Vista General | |||
| Vista Upgrade Problem - Windows Explorer Loop problem | Vista installation & setup | |||
