Go Back   Vista Forums > Windows Live > Live Messenger
Vista Tutorial - Problems with Messanger and Cam
Old 06-26-2009   #1 (permalink)
Senaj Lelic [DE MVP Visio]
Guest
Hi all,
i have the Windows live messanger and a strange problem: i have a builtin
cam in my laptop. and in the audio and video setup i do see the cam picture.
NOw when i start a conversation the cam is greyed out and it looks like my
messanger doesnt know about my cam.
Sometimes i switch a few times between the standard cam and the "cam"
(always the same hardware) and then it works for one time.. but the next
time i have the same issue again and most of the time i cannot activate the
cam at all.
Any ideas about the reason ?
the cam works just fine in Skype etc..
Senaj Lelic
maguro DataAssist GmbH
DE MVP Visio
Old 06-26-2009   #2 (permalink)
Jonathan Kay [MVP]
Guest
Re: Problems with Messanger and Cam
Greetings,
It's a bug, and the workaround is exactly what you already suggested (and then it will just
work for that session).
Jonathan Kay
Microsoft MVP - Windows Live Messenger
MSN Messenger/Windows Messenger
MessengerGeek Blog: http://www.messengergeek.com
Messenger Resources: http://messenger.jonathankay.com
(c) 2009 Jonathan Kay - If redistributing, you must include this signature or citation
"Senaj Lelic [DE MVP Visio]" <senaj.visio@xxxxxx> wrote in message
news:O2TmGpl9JHA.3244@xxxxxx
Quote:
> Hi all,
> i have the Windows live messanger and a strange problem: i have a builtin cam in my laptop.
> and in the audio and video setup i do see the cam picture. NOw when i start a conversation
> the cam is greyed out and it looks like my messanger doesnt know about my cam.
> Sometimes i switch a few times between the standard cam and the "cam" (always the same
> hardware) and then it works for one time.. but the next time i have the same issue again
> and most of the time i cannot activate the cam at all.
> Senaj Lelic
> DE MVP Visio
Old 06-30-2009   #3 (permalink)
Guest
ok but most of the time it doesnt work now anymore :-(
Is there a "sure to work" way ?
Senaj Lelic
DE MVP Visio
"Jonathan Kay [MVP]" <msnewsreplies@xxxxxx> schrieb im Newsbeitrag
news:uh6LiVt9JHA.4220@xxxxxx
Quote:
> Greetings,
> then it will just work for that session).
> Jonathan Kay
> or citation
Quote:
>> Hi all,
>> picture. NOw when i start a conversation the cam is greyed out and it
>> the cam at all.
>> Senaj Lelic
>> DE MVP Visio
Old 07-01-2009   #4 (permalink)
Jonathan Kay [MVP]
Guest
Go through the wizard and choose None, then go back through the wizard and choose the right
cam.
Additionally, don't use the 'Video call' but use the 'Show my webcam' option (click the
little cam icon under the display picture to quickly get to that option) on both sides and
use audio secondary.
Lame I admit, but it does the trick (or should anyway).
Jonathan Kay
news:OvO0QAY#JHA.5092@xxxxxx
> Senaj Lelic
> DE MVP Visio
Quote:
>> Greetings,
>> Jonathan Kay
Quote:
>>> Hi all,
>>> laptop. and in the audio and video setup i do see the cam picture. NOw when i start a
>>> conversation the cam is greyed out and it looks like my messanger doesnt know about my
>>> cam.
>>> Senaj Lelic
>>> DE MVP Visio
Old 07-21-2009   #5 (permalink)
Guest
great i'll chekc this !!!
THANKS !!
Senaj Lelic
DE MVP Visio
news:eXiw1Eg#JHA.1248@xxxxxx
Quote:
> Hi,
> choose the right cam.
> option (click the little cam icon under the display picture to quickly get
> to that option) on both sides and use audio secondary.
> Jonathan Kay
> or citation
>> Senaj Lelic
>> DE MVP Visio
>> Newsbeitrag news:uh6LiVt9JHA.4220@xxxxxx
Quote:
>>> Greetings,
>>> (and then it will just work for that session).
>>> Jonathan Kay
>>> message news:O2TmGpl9JHA.3244@xxxxxx
>>>> Hi all,
>>>> builtin cam in my laptop. and in the audio and video setup i do see the
>>>> cam picture. NOw when i start a conversation the cam is greyed out and
>>>> next time i have the same issue again and most of the time i cannot
>>>> Senaj Lelic
>>>> DE MVP Visio
Old 08-26-2009   #6 (permalink)
wiefisch
Guest
RE: Problems with Messanger and Cam
Hi Live Messengers
I had the same problem: webcam greyed out and only working on my side of the
video connection, but not on the other side. I solved the problem as
mentioned. Then the bug disappeared for some time. And yesterday the bug
suddenly raised up his head again. But now, the circumvention no longer
works. What is going on?
(applies to Windows XP and Windows 7, newest version. The same version on
Vista works fine at the moment). It appears like Live messenger would move
one step forward and two backwards from time to time.
"Senaj Lelic [DE MVP Visio]" wrote:
Quote:
> Hi all,
> cam at all.
> Senaj Lelic
> DE MVP Visio
messanger 2009 beta problems Live Messenger
More Problems with Live messanger Live Messenger
msn messanger Vista mail
SOUND in messanger Vista music pictures video
messanger live Vista General
