Go Back   Vista Forums > Vista Forums > Media Center
Vista - Media Player issues
Old 12-18-2007   #1 (permalink)
Vista Prem x64
Media Player issues
Hello all,
I've been using vista for about 8 months now, and I just built a new computer running Vista Prem x64. After working out a bunch of issues I've got it running pretty good, except when I use Media Player. Everythime I open it (if it will open) after about 5-10 min of use, it crashes my system. Everything locks up, nothing will respond and finally I get a black screen and have to hard reboot. Then I have to use my install DVD to recover my system.
I've had some issues with my wife's Emachine using Vista Basic 32 bit, so I upgraded it to Prem 32 bit, and now it's works great. So I'm wondering if my issue is due to it being 64 bit.
I think since I've installed this OS (x64 Prem) on my system I've had to recover it 8 times due to Vista crashing. The only thing I've done is update my Nvidia drivers from 163.75 to 169.04. I thought that might have been a issue to I changed them back to 163.75, and still the same issue. I'm kind of at a lost here, any advice would be great.
Thanks.
Old 12-18-2007   #2 (permalink)
Vista Ultimate X64
Re: Media Player issues
Hi Technogeek,
Please check your event logs and it should give a error code you can search microsoft.com for and give you an explanation as to why Vista is crashing. The event logs are located > Control Panel > administrative tools > look for Windows logs > "system log" and "application log"
Raj
Old 12-19-2007   #3 (permalink)
Vista Prem x64
Thanks a bunch, I did just that, and the code I got was c000218 which is registry file failure. By what I can tell, there are a lot of reason this code happens. I do remember when I used my recovery disk, there were two errors on my HDD, and it fixed them, after that it still would not load the OS, so I had to use the recovery disk again, and this time it took almost a hour to fix 2 issues. Like I've said I've had to do this a few times, so I wonder if it's just a issue with the OS being 64 bit and most software drivers only being 32. I have the OEM version, so I only have the x64 OS. I pretty sure it won't fix my issues, but maybe SP1 will help.
Old 12-28-2007   #4 (permalink)
Vista Ultimate X64
Ok. One thing I recommend doing is check the file system for errors and then run a check disk. Here is how:
http://www.vistax64.com/tutorials/66...les.html?ltr=S
http://www.vistax64.com/tutorials/67...isk.html?ltr=C
Raj
Media Player Issues General Discussion
Media Player Library Issues Vista music pictures video
Media Player 11 buffering issues Vista General
Media Player 11 Issues Vista music pictures video
Please help me! Windows media player issues! Vista music pictures video
