Go Back   Vista Forums > Vista Forums > Media Center
Vista - 64bit High Def proggy?
Old 12-20-2007   #1 (permalink)
vista 64 ultimate
I can get hd-dvd to run on vista 32bit with powerdvd ultra deluxe, but it just crashes on 64bit, anyone recommend some progs for 64bit
Old 12-21-2007   #2 (permalink)
Vista Home Premium 64bit
Re: 64bit High Def proggy?
Do you have a HD monitor? If not no proggy can turn your monitor into a HD monitor.
As for programs to view HD Video DVD. I would suggest googling it.
Sorry I am not much more help than that But I hate to see empty posts...
Old 12-21-2007   #3 (permalink)
vista 64 ultimate
Yes Ive everything you need to run HD except compatible 64bit software
Old 01-02-2008   #4 (permalink)
Vista Ultimate x64
Old 01-03-2008   #5 (permalink)
vista 64 ultimate
vlc plays h264 but I meant playing the actual hd-dvd discs (.evo files) powerdvd does it with 32bit but not on the 64bit
Old 01-03-2008   #6 (permalink)
Vista Ultimate x64,
For PowerDVD you will need to downgrade to PowerDVD Ultra 7.3.3319a if you want to play the movie from hard drive the newer version disable playing files from the hard drive.
I also believe some other versions with play from the hard drive but not sure.
I have this version and it works perfectly.
Old 01-05-2008   #7 (permalink)
vista 64 ultimate
works like a charm thank you!
Old 01-05-2008   #8 (permalink)
Vista Ultimate x64,
Glad it worked, have fun
Driver update proggy? General Discussion
64bit PC MACHINE, X86 WINDOWS,CAN I have 32bit & 64bit vista partitions General Discussion
Vista Premium 64bit to Ultimate 64bit Upgrade Fails Vista installation & setup
Upgrade from Home Premium 64bit to Ultimate 64bit - No 64bit Media Vista installation & setup
SigmaTel High Definition Audio Codec 64bit Driver Needed Drivers
