Go Back   Vista Forums > Vista Forums > Media Center
Vista - Tv Card Problem
Old 12-31-2007   #1 (permalink)
Vista Ultimate x64
Tv Card Problem
hi any body have slution for [Snazio TVPVR ]its software not work in vista x64 please tell what i do send me slution my id deemi592hotmail.com i wate for slution
thanks
Old 01-01-2008   #2 (permalink)
Windows Vista X64
Re: Tv Card Problem
Hi Deemi,
Welcome to Vista X64 Forums.
I am afraid unless the Manufacturer comes out with a Driver for Vista X64 you only option is to opt for a New Card.
(Try contacting the Manufacturer to see if a Vista X64 Driver has been/will be released.)
Old 01-02-2008   #3 (permalink)
Vista Ultimate x64
Re: Tv Card Problem
hi thanks for helping but vista upgrade my tv driver i want software for watch tv.i have chris tv software he is not tune tv.this is problem and can u tell me how i burn 6.5GB data in two DVD's like game.
thanks
Old 01-02-2008   #4 (permalink)
Windows Vista X64
Re: Tv Card Problem
Dont have much idea about Tv Softwares for Vista X64.Usually if your Card has a Vista X64 Driver then i think it'll have a compatible software too.Check the manufacturers Website.
As far as the 6.5GB is concerned you can burn it on a Dual Layer DVD(you will require only one DL DVD)
Else you can use a Splitting tool like "HJSPLIT" or even "WinRAR" to split the file into two parts and burn them on 2 Single Layer DVDs.
To get the file back you can copy both parts and merge them using HJSPLIT or extract using WinRAR.
2 LAN Card Problem Network & Sharing
SD Card Problem General Discussion
2 GB sd card problem Vista hardware & devices
SD card problem Vista hardware & devices
SD Card Problem Vista performance & maintenance
