Go Back   Vista Forums > Vista Forums > Media Center
Vista - How should I connect my PC to TV
Old 01-07-2008   #1 (permalink)
Vista Home Premium 32bit
What I want to do is:
Connect my Vista Media Center PC (located upstairs) to my 1080P LCD TV (located downstairs), the cabling distance between PC and TV is 12 mtrs.
Advice
I need advice from those with experience in setting up similar PC to TV connectivity. How to connect; quality of cables; signal over distance; etc. I have discounted wireless due to issues with signal reliability
PC Spec
Triple TV Tuner Card (DVB-T, DVB-S & Analogue), connected to it is a Skybox and Anlg Roof Aerial. PC also has a Blu-ray and HD-DVD drive and HDMI PC-to-TV output (supports HDCP).
I want to buy good quality products that will guarantee to deliver perfect High Definition sound & vision (version 1.3a) to my TV; and naturally I don't want to pay more than is necessary.
So, if you can assist me by first confirming what I want to do is feasible and second provide advice in finding good quality cables and if necessary repeater.
Have I missed anything out, is there something I haven't taken into consideration, am I completely crazy with what I want do?
Old 01-08-2008   #2 (permalink)
Vista Ultimate x64
Re: How should I connect my PC to TV
What you want to do is definitely feasible (and easy). All you need is a DVI to HDMI cable. Once you have it hooked up simply set your desktop resolution to 1920x1080 and off you go. It's just that easy.
Old 01-08-2008   #3 (permalink)
Windows 7 Ultimate x64
12 mtrs is a long way, tbh for the best advice on this I would ask on avforums - AVForums Home
Please let me know how you get on, as i'm looking at setting up a hd projector that will need a similar cable length to reach my skyhd & media center.
Can Connect to Router but unable to connect to internet Vista networking & sharing
"Connect automatically" checkmark disappears from "Dial-up Connect Vista installation & setup
"Connect automatically" checkmark disappears from "Dial-up Connect Vista networking & sharing
Can't connect to the internet, 3rd BRAND NEW computer that work connect! HELP! Network & Sharing
Re: Can't Connect to Juniper Network Connect 5.4.0 Vista General
