| Vista Home Premium 32bit | Best Tv tuner I was wondering what the best value for money tv tuner? All thoughts are appreciated ![]() And If you can, list some of the major channels recieved. Thanks, pjjppj |
| Vista Home Premium 32bit | Re: Best Tv tuner Best for a laptop/notebook |
| Vista Home Premium 64Bit | Re: Best Tv tuner If you don’t mind not having DVR capabilities right now, the Slingbox is the best product on the market by far. Plus, you can watch TV on any computer that you can log into the internet with. There are two ways to set up the Slingbox, one is to simply run a line from your Cable/Satellite to the Slingbox and you can watch the first 125 channels or so independently of what you have your cable box tuned to. The second way it to have the sling box inline between your cable box and your TV and then you can stream any channel that your cable box is tuned too, to any computer. NO drivers to install, No hardware to install, just the software to play TV on your computer or any computer (with an internet connection) you want to watch your TV. Check it out at Sling Media - Home of the Slingbox They are suppose to add DVR capabilites sometime down the road. |
| Vista Home Premium 32bit | Re: Best Tv tuner Thanks alot I think i may get one of those |
| Vista Ultimate X64 SP2 | Re: Best Tv tuner HP vista express card digital tv tuner w/remote Buy an HP ExpressCard TV Tuner for Windows Vista (RM436AA#ABA) from HP |
| | #6 (permalink) |
| Windows Vista X64 | Re: Best Tv tuner any other options? |
| | #7 (permalink) |
| Vista Home Premium 32 Bit | Re: Best Tv tuner for pc? any ideas. need it to connect AV inputs (Yellow, Red & White) amd possibly an ariel leed |
| | #8 (permalink) |
| Vista Home Premium 64Bit SP1 | Re: Best Tv tuner I've heard hauppage are really good. I have the WinTv Nova T-500. I had a few problems finding the correct vista x64 drivers when i upgraded but since i got them its been fine. Admittedly the software is ugly but i use it in media centre so i don't need it. I like the fact it has dual tuners so i can watch one channel and record another or record two channels at once. |
| | #9 (permalink) |
| Vista Ultimate X64 SP2 | Re: Best Tv tuner HP digital/analog tuner (above) is a rebranded hauppage. |
| | #10 (permalink) |
| vista ultimate 64 x 32 | Re: Best Tv tuner DigitalNow has a good selection of cards and good prices great support |
| TV tuner | Media Center | |||
| TV tuner | Vista hardware & devices | |||
| TV Tuner? | Media Center | |||
| TV Tuner help | Graphic cards | |||
| How Do You Get a Tv Tuner | Vista General | |||
