| Vista Ultimate x64 | WMP11/MCE cause system freezes - getting frustrating!!!---HELP!!!! Ok, I've poked around the web for 2 days now, and you guys seem like a knowledgeable place. I recently upgrade my system,went to an AMD 770 chipset with an AMD X2 6400+ and 4GB of DDR1000 ram. With my new ram upgrade, I opted to install Vista x64 This hasn't been the most pleasant, first I find my Hauppauge TV card doesnt like more than 3.2GB of ram, ok, I can fix that, I'll use my USB tuner. but then, and this is the part I can't solve. Watching live TV or recorded, after a while the whole system will lock up, no bsod, no reboot, no error....just freeze. Since it freezes in this manner, there are no error logs, no event logs...nothing. so I say screw it, I'll go back to watching normal TV...ick, but then I noticed playing music or video in WMP 11 causes the same results, at least in 32bit for sure, I left my PC back home running WMP 11 64bit playing music, if I get back and find it dead, then its WMP 11 in general. My question is why, why does it freeze? The only semblance of an error I found in the event logs were a few errors produced by l3codecx.ax, the mp3 under layer codec if I'm not mistaken. but that seems unlikely. is there an updated codec I can try, or another update/patch I've missed help is much appreciated, thanks in advance! -IL |
| Vista Ultimate x64 | Re: WMP11/MCE cause system freezes - getting frustrating!!!---HELP!!!! Ok, I think I may have found the problem, or it's two fold, I did the silly thing of changing two things at once, but I'm sure it wasn't my moving the sound card to a different PCI slot. I removed ReadyBoost, I was running a 2GB SD card in readyboost along with my 4GB of ram, I just kind of carried it over with me from Vista x86, and didn't think much of it at the time. I let my PC run overnight playing music through Media Center, I woke up expecting a frozen box...but no! the music still played! so, for anybody else with a similar problem, try disabling readyboost! if the problem returns, I'll update. |
system freezes when using sli for games | Gaming | |||
| Minimize WMP11 to System Tray | Software | |||
| System Freezes in between - Pls help | General Discussion | |||
| WMP11 Freezes while syncing | Vista music pictures video | |||
| System Freezes when uploading | Vista performance & maintenance | |||
