Go Back   Vista Forums > Vista Forums > Media Center
Vista - Xbox 360 Extender: Connection Failed
Old 02-23-2008   #1 (permalink)
Ultimate x64
This is my first post, so i'd like to start off by saying hello I'm reallying liking the information on this forums so far.
Anyway down to bidness..
I recently had an issue with my xbox 360 extender after disabling one of the media center extender services in vista x64 ultimate. After trying trying to connect to the media center service i got this error:
Connection Failed
The Xbox 360 cannot connect to the Media Center based PC. Make sure the Media Center based PC is turned on and connected to the network. If you continue to see this error, check Media Center Extender Help on your Media Center based PC.
Did a little digging and found this MS KB which resolved my problem. Hope it is of some use to you guys.
Article 932163
Old 02-24-2008   #2 (permalink)
Ultimate x64
Re: Xbox 360 Extender: Connection Failed
I neglected to mention that i recieved the error after re-enabling the PnP-X-IP Bus Enumerator service.
Old 08-31-2008   #3 (permalink)
Vista Home Premium 32bit
I have the same problem. I deleted the certificate but I still get the same error.
Old 08-31-2008   #4 (permalink)
Ultimate x64
yeah, i have the problem happen to me sporadically. sometimes that fixes it, other times i just get really pissed off :P i actually don't even use it for a media center extender anymore. I think i'll try it again on my next OS re-install.
Old 09-01-2008   #5 (permalink)
I found my problem - it was that I had an alternate MAC address for the xbox. Not sure why that was there but anyway, I deleted that and everything worked. Crappy software from someone. What was bizarre that everything worked fine with XP MCE 2005. Nice one Microsoft.
Vista Ultimate Xbox 360 Extender Connection - Configuration Error Vista General
Xbox 360 Extender Media Center
XBOX 360/Media Extender -- Can't connect to xbox live after configuring extender... Vista General
Re: XBOX Extender Program does not find XBOX Vista General
