Go Back   Vista Forums > Vista Forums > Media Center
Vista - Media Center works great, but sound is usually LOW!?
Old 02-26-2008   #1 (permalink)
Vista Ultimate 64-bit SP2
Hi all...have you guys experienced this? Even when turned all the way up, the video playback is great, but the audio is simply too low. Virtually every time. I installed some x64 codecs, but to no avail.
The same happens on my 2nd T60p which runs Vista Ultimate 32-bit. I use the VideoLAN player, which plays back almost anything, and I also am the proud owner of a license for PowerDVD Ultra, Deluxe version. No audio problems there. I have installed Service Pack 1 on both Ultimate x64, as well as x86, and the issue is the exactly the same.
Am I overlooking a small thing, such as not putting a checkmark in the right place? Is there some other kind of workaround?
Thanks all!
Old 02-28-2008   #2 (permalink)
Win7 Ultimate 64bit
Re: Media Center works great, but sound is usually LOW!?
I know this is prolly a dumb question but have you gone into control panel and made sure your speaker setup is correct (5.1 or 7.1 etc) and checked the volume levels? I know it sounds silly but I've seen it happen a hundred times.
Old 02-28-2008   #3 (permalink)
Vista Ultimate x64
This may also seem like a dumb question, but are you watching HD videos? Because HD is broadcast/Encoded in 5.1 by default, so if you're like me and watching HD programming in stereo, you'll have to crank your speakers almost all the way up.
Old 06-18-2008   #4 (permalink)
Vista Ultimate 32 & 64
From what I understand, a lot of HD content has audio with a much wider volume range/spectrum/whatever...
I have this problem all the time when I switch from my analog cable channesl to ATSC HD OTA channels... annoying, but not much we can do about it I guess.
Some a/v recievers have "night modes" or similar, that condense the volume range so you don't have to constantly turn the volume up and down... I hate that...
Old 06-19-2008   #5 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Well, I hate to dispel the suggestions, but I run my sound through my AV receiver, using my home made Dolby Surround Sound with main, rear and center speakers, and I have a Hauppage TV Tuner and am still on analog cable - but whenever I run MCE in Vista (both 32bit before and 64 bit now) the volume from *anything* in MCE is lower than standard windows - and I have even checked the mixed when MCE is running -0 it is at 100%, my overall volume it as 100%, but whereas normally I run my receiver at about 5-7% (at 25% it is almost deafening - great for metal, but not so good when Vista pops up a critical error at 2 AM when you're doing homework and ppl are sleeping) but whenever I turn on MCE I have to push the volume on the receiver up past 12-13% - effectively doubling the volume.
Also, that gets annoying if windows decides to beep at me while I am watching something (like the Boston Celtics' spectacular win Tuesday night). I usually run MCE on one monitor and read forums and such on the other, but every now and again I'll miss a click or something - usually trying to click on one monitor while looking at the other....and the sound are *extremely* loud compared to the cable signal volume. and yes, MCE is maxed at 50.
Vista RTM installs & runs great, Media center app crashes Vista installation & setup
Codec works in media player not in media center Vista music pictures video
Which DVD software works with Media center Vista hardware & devices
Media Center - Works now! But sound is choppy Vista General
Windows Media Player 11.0 Beta Works Great in Windows Vista Build 5308! Vista General
