Go Back   Vista Forums > Vista Forums > Media Center
Vista - Vista x64 TV Tuner with Comcast Digital Cable
Old 06-19-2008   #1 (permalink)
Vista x64
Hi. I have Comcast digital cable and until recently have been fine using my Hauppage WinTV PVR 150, and more recently 500. However, I upgraded to 4gb of ram and Vista x64, and neither card works. I am looking for a card that would let me continue using media center. I have also heard that with some cards you do not need a STB, is that true? thanks.
-Core 2 Quad, 2.4ghz
-4gb Ram
-Nvidia 8500
-Soundblaster Audigy
-Comcast Digital Cable
Prefer PCIe, but PCI is OK
Old 06-19-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: Vista x64 TV Tuner with Comcast Digital Cable
Have you taken out the memory and seen if the cards work again? If so then there might be a BIOS setting / update that might make 4 GB RAM work with the cards....
Old 06-30-2008   #3 (permalink)
Vista Ultimate x64
Quote  Quote: Originally Posted by sanderlebau View Post
-4gb Ram
-Nvidia 8500
send an email to Hauppage and tell them about your situation. They'll send you beta drivers for systems with 4GB of RAM. My HVR-1600 didn't work right in Vista64 with 4GB of RAM until I updated my driver to the beta version
Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H Vista General
Which HDTV Tuner card to use as a DVR with digital cable Media Center
Vista Ultimate + Comcast w/digital cable Media Center
WMC/TV Tuner and Digital Cable Box - Scrambled Signal Vista General
Comcast cable box setup Vista installation & setup
