Go Back   Vista Forums > Vista Forums > Media Center
Vista - Svideo Cable Issue with laptop
Old 06-27-2008   #1 (permalink)
Windows XP SP3
I am running Windows Vista Home basic and I am haveing a problem.
What im trying to do is to basicaly use my TV as a monitor and i cant seem to get the settings working im very new to vista
I pluged My Svideo cable into my laptop and the "Yellow Adaptor"(as in the red yellow and whte cable) into the yellow video port on my tv in the same way id hook up a console and all i get is a blank screen on my TV I dont know what else im suposto do to Watch movies on my tv
I havent touched any of the settings on my laptop so if someone could walk me through it that would be great
Ty
Old 06-27-2008   #2 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Re: Svideo Cable Issue with laptop
Hi, daisuke2, and welcome to the forums.
If you check your laptop's user guide, you'll find the exact procedure, but most laptops have a special key combination on the keyboard to allow the external port to be enabled. On many laptops, especially Dells, I have seen the combination being the Fn key (usually located in the bottom left hand corner) and the F4 or F5 key (If you look carefully, usually in an off color, like purple, or green, or gray, you'll see a couple of icons that look like a monitor (and one looks smaller than the other) separated by a / - that is the correct Fx key to use with the Fn key.
Also, for future reference, you have to remember that when you ask a question, you need to be *very8 specific and include all information possible - for example, I don't know if you're running Vista 64bit or 32bit (not really important), and I don't know if you've ever used an external video display device with your laptop or not, and *most important* I have no idea what your laptop model number is - because with the model number I could download your manual from the manufacturer website and tell you exactly what page to look on to find what I am talking about.
HTH
VGA cable from laptop to TV Graphic cards
Network Cable Unplugged Issue Network & Sharing
to contact a vista laptop to xp laptop using a crossover cable Vista networking & sharing
easy transfer cable driver issue Vista General
Communications cable between two computers issue Vista networking & sharing
