Vista Forums Home Join Vista Forums Donate Windows 7 Forum Vista Tutorials Tags
Welcome to Windows Vista Forums. Our forum is dedicated to helping you find solutions with any problems, errors or issues you are experiencing with Windows Vista. The Vista forum also covers news and updates and has an extensive Vista tutorial section that covers a wide range of tips and tricks.
Go Back   Vista Forums > Vista Forums > Media Center
WMC -garbled audio = HELP
LinkBack Thread Tools Display Modes
Old 07-04-2008   #11 (permalink)
eknirb's Avatar
Vista Home Premium 32bit
Re: WMC -garbled audio = HELP
no, i don't know where to locate them. Could I just reinstall WMC and over write what's already on the PC?
Old 07-04-2008   #12 (permalink)
johngalt's Avatar
Antidisestablishmentarian
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Did you install WMC before? and do you have the program installer to install it again?
Sorry, but it is a part of Vista - do you want to perform a Vista re-install? That is usually the absolute last step I recommend, because it entails hours of work backup up your data, noting your serial numbers, backing up settings, formatting, installing Vista, installing applications, installing drivers, etc.
What model TV Tuner card do you have? You devices are all located in Device manager - check the version you have installed and see if a newer version is available for it....if not, then remove the device and then let Vista find it and then reinstall the drivers when it asks for them.
You seem hellbent on trying ti uninstall and reinstall WMC, but you are not looking at the bigger picture - the problem is with ***LIVE*** TV - not other media - so why would it be WMC's fault?
Old 07-04-2008   #13 (permalink)
eknirb's Avatar
I just want it to stop freezing. Where is Device manager located?
Old 07-05-2008   #14 (permalink)
johngalt's Avatar
Vista also has this search bar in your start menu - most things you want to find you click on the start button and then type what you are looking for - so that is really the fastest way to open device manager - click start, type device, and then look at the top, and you *should* see Device Manager.
Display Modes
Subject garbled Sara Vista mail 0 04-06-2008 11:46 AM
Garbled messages at Recipients? argyliz Vista mail 1 12-30-2007 08:46 AM
Sound is Garbled JLC Vista hardware & devices 1 11-04-2007 07:10 PM
garbled sound andy Vista music pictures video 3 08-08-2007 01:07 PM
Sound garbled Andrew Vista hardware & devices 0 03-08-2007 03:08 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53
