| Vista Home Premium 32bit | WMC -garbled audio = HELP About a week ago..after seven mos of perfect playback...WMC would all of a sudden freeze during playback of live TV. Would have to close it and restart. Now... If it starts OK..the audio playback is gibberish. Nothing has changed as far as settings go. Worked last nite..now it's gibberish audio. Other audio playback from PC, like iTunes, is fine. Now, what can I do here? |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: WMC -garbled audio = HELP Check your TV Tuner drivers.... |
| Vista Home Premium 32bit | Re: WMC -garbled audio = HELP and how would I do that? how would I replace them? PS- a reboot corrected the gibberish problem. I would still like to make it so it didn't FREEZE anymore. would a reinstall over current program from the source install CD help? |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: WMC -garbled audio = HELP I would uninstall and then reinstall.... |
| Vista Home Premium 32bit | Re: WMC -garbled audio = HELP ok. how do i do that,,since its not on add/remove? |
| | #6 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: WMC -garbled audio = HELP Drivers are usually never going to be in add / remove - you'll need to go to Device Manager to remove drivers. Click the Start button and then in the search bar type device - you should see it pop in at the top of the list. |
| | #7 (permalink) |
| Vista Home Premium 32bit | Re: WMC -garbled audio = HELP so theres no way to remove WMC? |
| | #8 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: WMC -garbled audio = HELP Umm, why would you want to remove MCE? If it is only happening on Live TV I'd check your TV tuner first as it interfaces between your cable and your computer - MCE has nothing to do with that, it just displays what it gets from the tuner. |
| | #9 (permalink) |
| Vista Home Premium 32bit | Re: WMC -garbled audio = HELP MCE? Do you mean WMC, Windows Media Center? I just want the freezing of the player to stop. The garbled audio has disappeared since I rebooted. |
| | #10 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: WMC -garbled audio = HELP Media Center Edition - the old acronym for Media Center. Sorry, old habits die hard. So, have you tried uninstalling and reinstalling your TV tuner drivers? |
| Menus Garbled | Live Mail | |||
| Garbled Audio | Sound & Audio | |||
| Subject garbled | Vista mail | |||
| Sound is Garbled | Vista hardware & devices | |||
| garbled sound | Vista music pictures video | |||
