Vista Forums Home Join Vista Forums Donate Vista Tutorials Tags
Register at Vista forums...the world biggest Windows Vista resource Join Vista Forums Now
Go Back   Vista Forums > Vista Forums > Media Center
WMP11 - when ripping a cd gives "Error"
Update your Vista Drivers Update Your Drivers Now!!
Thread Tools Display Modes
Old 07-02-2008   #1 (permalink)
Newbie
Vista Home Premium x64
sept298901 is on a distinguished road
  sept298901 is offline
I have two cd/dvd drives in my computer (SAMSUNG SH-S203) and when i insert a cd to rip onto my computer the cd loads and the computer recognizes it (in either drive). When i go to the rip tab in WMP11 i click on "Start Rip" and it shows the progress on the first song, rips up about 30% then it says failed, then all the other songs that are pending say fail. Im just a little mad because it does not give any error codes or anything, it just says "error under" the "rip status" tab. any assistance on how to get the details of the error, or to fix the error would be greatly appreciated.
I am running windows vista x64, quad q6700, 9800 gtx, 8 gb 4x2gb CorsairXMS2 DHX, evga 780i, wmp 11.0.6001.7000
Thanks
Old 07-03-2008   #2 (permalink)
johngalt's Avatar
Antidisestablishmentarian
Vista Ultimate x64 MAK
3rd Rock
johngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant futurejohngalt has a brilliant future
  johngalt is offline
Re: WMP11 - when ripping a cd gives "Error"
Are you overclocking?
Old 07-03-2008   #3 (permalink)
Newbie
nope, running at 2.66 GHz
Old 07-03-2008   #4 (permalink)
johngalt's Avatar
3rd Rock
  johngalt is offline
Have you tried running SFC /SCANNOW to see if you have corrupted system files? Have you tried any other diagnostics?
Old 07-04-2008   #5 (permalink)
Newbie
I tried the SFC /SCANNOW and it did not find any problems. i have not tried any other diagnostics programs yet, primarily because im having a hard time finding any.
Thanks
Old 07-04-2008   #6 (permalink)
johngalt's Avatar
3rd Rock
  johngalt is offline
Hmmm....
How many different discs have you tried? Older content or all brand new stuff? I am beginning to think that it might have to do with DRM related stuff....
Old 07-04-2008   #7 (permalink)
Newbie
i have tried probably five different disks- i do not have the copyright protection option enabled, and i tried switching up the bit rates as well as the format.
Old 07-05-2008   #8 (permalink)
johngalt's Avatar
3rd Rock
  johngalt is offline
Hmmm - well this one has me stumped....
Old 07-06-2008   #9 (permalink)
Newbie
is there any way to get an error code or something. all that i can see is "error" but if i had some details on the error i bet i could get a little further.
Old 08-06-2008   #10 (permalink)
Newbie
Vista Home Premium 32
Mississauga Canada
dougone is on a distinguished road
  dougone is offline
I see this was posted some time ago without any resolution. I too am experiencing exactly the same problem. The only thing I can add is that the same message occurs whether I try ripping with Windows media or itunes/Quicktime. Come to think of it, this may have started to occur after i loaded itunes. Any solutions yet?
Display Modes
Exception calling "Send" with "1" argument(s) error using PING bass_player PowerShell 4 07-08-2008 10:32 PM
wmp11 "ran out of Memory" error code C00D11C6 mftr Vista General 2 05-20-2008 04:39 PM
Vista gives "not enough space" error when copying to "Documents" Shaddix Vista file management 1 07-14-2007 01:22 PM
WMP11 and Vista Ultimate won't playback purchased "ripped" CD's Blue in Frisco Vista music pictures video 3 06-01-2007 07:14 AM
"Completing Installation..." *Resets Unexpectedly* "Error" Aiden Vista installation & setup 1 03-10-2007 07:48 PM
Update your Vista Drivers Update Your Vista Drivers Now!!
Vistax64.com is an independent web site and has not been authorized,
© Designer Media 2005-2008
