| vista ultimate 32bit | ehome receiver not found in HID hi guys, i used to have a fully working media remote when i first built the Media Centre but to make a long story short it stopped working,. uninstalled installed a few times now not working at all. there is no microsoft ehome receiver in my human interface devices but used to be there when it used to work so think this is where the problem lies. where can i download a replacement, is there such an animal for vista ultimate? Is there any way i can get this baby to work again. at the moment am forced to use mouse any help is good help, Luke |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: ehome receiver not found in HID The driver is built into Vista- if it is not showing up it is possible that it is 'hidden' - go to view and select Sow hidden devices. If you can now see it and it (perchance) has an Error Code 10 (Device not currently connected) then try plugging the transceiver into another USB port - if it still doesn't work try another computer. Either the receiver is bad, or your USB port(s) is(are) bad, or your operating system is going slowly to pot. |
| vista ultimate 32bit | Re: ehome receiver not found in HID The driver is built into Vista- if it is not showing up it is possible that it is 'hidden' - go to view and select Sow hidden devices. If you can now see it and it (perchance) has an Error Code 10 (Device not currently connected) then try plugging the transceiver into another USB port - if it still doesn't work try another computer. Either the receiver is bad, or your USB port(s) is(are) bad, or your operating system is going slowly to pot. dont really want to reinstall vista but running out of ideas. |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: ehome receiver not found in HID Quote: if it is not showing up it is possible that it is 'hidden' - go to view and select Sow hidden devices. If you can now see it and it (perchance) has an Error Code 10 (Device not currently connected) I'd also perform a SFC/ SCANNOW |
| vista ultimate 32bit | Re: ehome receiver not found in HID hi, integrity if good, windows resourse protection didnt find any integrity violations so dont know what to do next. as there is no ehome mce receiver in my HID(device manager) i cant install or update. there is a mce infrared remote in the usb section but properties says it is working fine. have tried show hidden but this didnt make any difference, still not there. are there any other options open to me? Quote: if it is not showing up it is possible that it is 'hidden' - go to view and select Sow hidden devices. If you can now see it and it (perchance) has an Error Code 10 (Device not currently connected) I'd also perform a SFC/ SCANNOW |
| | #6 (permalink) |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: ehome receiver not found in HID Yup - close Device Manager, then open a command prompt and type the following *exactly*: Code: set devmgr_show_nonpresent=1 Code: start devmgmt.msc Now, in Device Manager, try showing hidden devices again. Also, when you are in there, make some screen shots to post.... |
| | #7 (permalink) |
| vista ultimate 32bit | Re: ehome receiver not found in HID done as asked and still nothing showing that wasnt already there. have saved screen shot to hard drive and also one from my brothers pc who is running exactly the same media Centre setup as mine. same hardware and software, except tuner cards. He definately has something extra. how do you post a pic from my hard drive. looks like i have to up load pic from a url. does this mean i have pic uploaded to a web page or similar? bugger~! |
| | #8 (permalink) |
| vista ultimate 32bit | Re: ehome receiver not found in HID hi, this is a followup on the screen captures. The screen capture 01 is from my pc and the device manager screen capture is from another pc with the same build and with remote working. hope this helps, |
| ehome wireless keyboard & remote | Vista hardware & devices | |||
| eHome package changes from Norwegian to American...? | Vista General | |||
| media center keys - channel change etc... eHome ... | Vista General | |||
| eHome Infrared Receiver prevents standby | Vista General | |||
| CHIC eHome Infrared Transceiver | Vista hardware & devices | |||
