| Vista Home Premium 32Bit | need TV Tuner help Ok i bought my HP pavilion DV600 laptop about a year ago with XP preinstalled. i later got Windows Vista Home Premium 32bit. The TV tuner came with my purchase with the laptop. With XP i could use the TV tuner with Media Center perfectly, after i installed Vista it worked fine too i belive. a few months later i reformatted my hardrive and reinstalled Vista and my TV tuner would no longer work. I took some pictures of what happens. and some of the TV tuner card. By the way the Model is HP EC680 Analog TV Tuner ![]() ![]() ![]() ![]() ![]() I took a screenshot of this error with the error log ![]() ![]() In this pic u can see the TV tuner plugged in but it says its not installed ![]() |
| x64 Home Premium | Re: need TV Tuner help may be a driver issue, make sure you have up to date drivers for the tuner card, for vista x32, from the card manufacturers website. Windows Update will sometimes update drivers for you, but, those drivers may not be the proper match. . . |
| Vista Home Premium 32Bit | Re: need TV Tuner help kk ill try it. thanks for the help. |
| Vista Home Premium 32Bit | Re: need TV Tuner help cant find a driver. anybody else can help? |
| x64 Home Premium | Re: need TV Tuner help |
| TV tuner | Media Center | |||
| TV tuner | Vista hardware & devices | |||
| TV Tuner? | Media Center | |||
| TV Tuner help | Graphic cards | |||
| How Do You Get a Tv Tuner | Vista General | |||
