Go Back   Vista Forums > Vista Forums > Media Center
Vista - TV Channel wont play at first - "The Channel May Not Be Supported" (it is)
Old 08-09-2008   #1 (permalink)
Vista Ultimate SP2/Windows 7 Ultimate x64
After months of flawless performance my WMC is acting up on one TV channel and I can't figure out why.
The only change recently was that I enabled the DVD Library to be displayed with a registry hack as per a seemingly reliable article I read.
This is only happening the first time after I boot.
I call up WMC and go to the TV Guide. If I select Channel 50 (only) it will not tune in and I get a screen that says
"Cannot Play Program"
"The channel may not be supported. If you cannot tune to any other channel,
restart WMC or restart the computer, then try again"
If I then use the guide to go down or up one channel they play OK and
returning to ch50 - it then plays fine. Very odd.
Any ideas anyone?
The registry tweak was, I realised afterwards, unnecessary as I'm not using
this machine as a media center anyway and I'm not sure what the original
setting was.
Now it is set at..
HKCU>Software>Microsoft>Windows>CurrentVersion>Media
Center>Settings>DVDSettings
Showgallery - regsz - gallery
I have tried reloading the guide from my cableco and it seems to go without any hitch.
Old 08-11-2008   #2 (permalink)
Vista Home Premium 64bit
Re: TV Channel wont play at first - "The Channel May Not Be Supported" (it is)
It might seem painfully obvious but have you tried removing the DVD library registry hack you mentioned...everything seemed to work, as you said, before that hack
Old 08-11-2008   #3 (permalink)
I would if I knew what the default entry is for that particular item. I don't have a restore point unfortunately.
I found the "hack" which is a misnomer I suppose as Microsoft published it: http://support.microsoft.com/kb/930526
Old 08-11-2008   #4 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
Code:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings\DvdSettings]
"ShowGallery"="Play"
Copy the text above into notepad, save as a .reg entry on your desktop, then import it into the registry.
Voila!
Old 08-11-2008   #5 (permalink)
Thanks. After 1 reboot it seems to be OK. I'll keep an eye on it. Much appreciated.
Old 08-11-2008   #6 (permalink)
Yer welcome - and a beautiful signature image there as well.
Old 08-11-2008   #7 (permalink)
Thanks.
Old 08-14-2008   #8 (permalink)
It's doing it again, so there must be a glitch somewhere. If I go straight to live TV and 50 is the last channel I had tuned to, it gives the error. But if I then call up the guide and click on the channel from there it plays.
Very strange and it appears to be only that one channel out of the 100-odd that I can bring in.
Old 08-14-2008   #9 (permalink)
Is it possible that that channel is simply experiencing a lot of interference on your cable line? I'd call the cable company and have them run line tests....
Old 08-14-2008   #10 (permalink)
Did that and it tested out OK. It has no problems via cable direct to my TV either. I think something has corrupted the WMC database somehow. It's not serious as I can eventually tune it in.
Channel 9 to swallow Channel 8, Channel 10, and Coding4Fun Vista News
Error on return from function call in ASP.NET "Operation is not supported on this platform." .NET General
2 GB dual channel vs 3 GB single channel Vista hardware & devices
ATA/ATAPI: IDE Channel and ATA Channel Vista hardware & devices
Vista x64 Doesn't like Memory plugged in as "Dual Channel" Vista General
