Go Back   Vista Forums > Vista Forums > Media Center
Vista - Does Media Center need Media Player to work?
Old 08-18-2008   #1 (permalink)
Vista Ultimate 32bit
Hey all,
I'm new to vista and i'm just wondering...just media center require media player to work? If not is it possible to remove wmp11? On that note, is it also possible to remove IE7? As I am a devoted Firefox user
Old 08-18-2008   #2 (permalink)
Microsoft® Windows Vista™ Ultimate x64 SP2 Windows 7 7127 x64
Re: Does Media Center need Media Player to work?
You do not need media player to use media centre as they are two slightly different applications, you do not have to use either and can in fact download any other player or only use media centre. You can remove wmp11 but once again you can just disable it.
You do not have to remove IE7, set Firefox as your default browser and forget about it.
Old 08-19-2008   #3 (permalink)
Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1....
You *cannot* remove IE as it is tied in to Vista even tighter than it was in XP. Take a look at your history, and you should see some local paths from your Windows Explorer....
Old 08-19-2008   #4 (permalink)
Cool, thanks for help. So can someone tell me how to remove wmp11. I know you can just disable it or choose something else as your default player but i am a padantic.
Cheers,
Jordan.
Old 08-19-2008   #5 (permalink)
Vista Businesss 32bit, Vista Home Premium 32bit
Media Center gets it's library information from media player. I'm 99% positive that if you removed media player, it would hose media center.
Old 08-19-2008   #6 (permalink)
Vista ultimate sp1 64 bit
In the above post- Yes media player does the file fishing for ripping discs with media center. So you are s.o.l and will have to type in your own titles etc, but media center will function without it. not sure how you would get art should you need it. there are several players out there, and the new adobe player looks interesting. havent tried it yet though.
As for the removal; these are the days of abundant hard drive space.WMP is not a file worth trippin' about as far as consumption or space. just ignore it and set something else up as your default player. If it could be totally removed it would most likely corrupt some shared files or codecs and then you would have problems.
In control panel / internet options, it's still somewhat the same as xp. use your browser of choice and configure int. xploder 7 (not a typo) as neccesary.
I call em as i see em.......
Saving Internet radio stations in Media Player and/or Media Center Vista music pictures video
Media center, photo gallery and media player turn black screen Vista music pictures video
Windows Media Player and Media Center not working properly Vista music pictures video
Vista Crash Windows Media Player/Media Center Vista General
Media Center and Media Player mouse doesn't work properly Vista General
