| Vista Home Premium x64 | Help? Removing Dispay Icons? How do remove display icons/folders when the folders in question are not set to view in the options SEE PICTURE ImageShack - Hosting :: screen0000hz0.jpg Last edited by magicalones; 08-31-2008 at 12:30 AM.. |
| Vista Ultimate x64 MAK, OpenSolaris 5, Gentoo 2008.1.... | Re: Help? Removing Dispay Icons? You'll want to edit your media library and remove check marks beside places you no longer want included in your media library. |
| Vista Home Premium x64 | Re: Help? Removing Dispay Icons? John these weere not watched folders so there is nothing to check or uncheck... i did figure it out and it wasnt easy.......should someone need the answer ill be glad to help! |
| Microsoft® Windows Vista™ Home Premium | Re: Help? Removing Dispay Icons? you should post what you did, so everyone can know. Plus other people can maybe find it. |
| Vista Home Premium x64 | Re: Help? Removing Dispay Icons? Rebuilding/Reindexing Folders In Windows Media Center The instructions are:
| Removing Font from desktop icons | General Discussion | |||
| removing desktop icons | Vista General | |||
| removing unneeded taskbar icons | Vista General | |||
| Removing System Tray icons! | Vista performance & maintenance | |||
| Removing the arrow from shortcut icons | Vista General | |||
