Go Back   Vista Forums > Vista Forums > Media Center
Vista - Which HDTV Tuner card to use as a DVR with digital cable
Old 09-23-2008   #1 (permalink)
Vista Home Premium 32bit
I would like to use my Vista Media Center as a DVR using a Media Extender. I have digital cable (Comcast). I would be using it just to watch recorded shows on my HDTV using a Media Extender and would not be watching TV on my PC.
I want a HDTV tuner card that will record programs from my digital cable using Media Center Software, not proprietary software.
Any HDTV tuner cards fit this bill? Can be PCI or USB cards (my PCIe is taken by my graphics card.).
Thanks.
-Scott
Old 09-29-2008   #2 (permalink)
Vista Ultimate x64
Re: Which HDTV Tuner card to use as a DVR with digital cable
As far as the HD Tuner goes, I like the huppauge tuners, they work well in my ultimate x64 system and look and work great. However, a few things you will have to consider...
1. With your comcast cable, will you be using a set-top box, or just standard cable signal?
2. With your HD tuner, will you be attempting to record OTA HD (Over-The-Air) as well as standard cable?
Just by getting an HD tuner does not make the signal quality HD. In fact, if you get an HD tuner, make sure its a Dual tuner in your case. Media center is written to accommodate HD cards before analog. Basically, if you buy an HD, all you will get is HD regardless of whether or not you use a standard cable signal. (Run into this problem numerous times). So, if you plug your comcast cable into an HD card running under Media Center, it won't see the analog stations but will try to find HD stations and fail.
Best solution is to buy one Dual ATSC tuner or one analog and one HD tuner.
Hope that helps
Old 09-29-2008   #3 (permalink)
Vista ultimate 32
I just got a SiliconDust HD HomeRun, It seems to work quite well for clear QAM. I have an issue with WMC the predates the tuner.
Old 09-29-2008   #4 (permalink)
Vista Ultimate x64
Whats the issue?
Old 09-29-2008   #5 (permalink)
Vista ultimate 32
Quote  Quote: Originally Posted by Pbb321 View Post
Whats the issue?
WMC will not run setup completely. The problem is due to an analog tuner that came with a MC 2002 computer. I am pretty sure it hosed WMC, and sure it has nothing to do with Silicon Dust.
Old 09-29-2008   #6 (permalink)
Vista Ultimate x64
May or may not be vista compatible. More than likely not. Any updated Drivers out there?
Old 09-30-2008   #7 (permalink)
Hope that helps
Ended up getting the Hauppauge 1600 Hybrid. It seems to work great so far. I am not using a set top box, just standard cable signal. I get channels 2-75, and 99.
I'd like to use the other tuner. Can I split the cable or do I have to get an antenna? How do I set MCE up with 2 tuners? Thanks.
-Scott
Vista Digital Cable OEM PC w/ ATI TV Wonder Digital Cable Tuner -H Vista General
WMC/TV Tuner and Digital Cable Box - Scrambled Signal Vista General
HDHomeRun Networked HDTV Digital Dual TV Tuner Vista hardware & devices
HDHomeRun Networked HDTV Digital Dual TV Tuner Vista General
HDHomeRun Networked HDTV Digital Dual TV Tuner Vista music pictures video
