Go Back   Vista Forums > Vista Forums > Media Center
Vista - Media Center keeps auto starting??
Old 11-13-2008   #1 (permalink)
Vista Ultimate
In my computer, Window media center is auto start when reboot. It made me sick.
I try so many way but it still auto start
I already try under ways but it still auto start ..
1.Control panel > System > Performance information and tool manage start up program (disable Window media center)
2.msconfig > ??? I can't found window media center in start up tab
3.Disable Windows Media Center Services Open Services (type services.msc into Start Search). Locate all services related to Windows Media Center, such as Windows Media Center Extender Service, Windows Media Center Receiver Service, Windows Media Center Scheduler Service and Windows Media Center Service Launcher, and any other services started with “eh” as command names, then set their Startup Type to Disabled.
Stop Windows Media Center Services from Start Up
Run MSConfig (System Configuration) and go to Startup tab. Uncheck the item entries which has the ehome as path to the command, such as ehTray.exe. This will prevent MCE related services to be startup up. To be safe, you still need to disable WMC services as above.
I try it but it donesn't work
Still auto start when I reboot or boot
please help me
Old 11-15-2008   #2 (permalink)
vista home premium SP1 32bit
Re: Media Center keeps auto starting??
open MSCONFIG and then go to SERVICES tab, and then scroll down the list and find WINDOWS MEDIA CENTER SERVICE LAUNCHER.. . there should be a tick in the service launcher check box, - remove it - and then click apply followed by ok
then restart your computer and see if this works
let me know the outcome mate
Old 03-11-2009   #3 (permalink)
vist 64 bit
Have you tried the simple method of going to control panel and then to autoplay then to dvd movie and select take no action?
media center auto restart Media Center
Computer auto starting Vista account administration
Vista Home Premium and auto starting programs Vista General
Screen out of Range (below 60 Hz) when starting Media Center in Vi Vista music pictures video
Screenrefresh out of range when starting Media Center in Vista 538 Vista General
