Go Back   Vista Forums > Vista Forums > Media Center
Vista - wmv problem
Old 11-16-2008   #1 (permalink)
Vista Home Premium 32bit.
wmv problem
I have Vista Home Premum SP1. I cannot play some wmv files on windows media player 11. Same files are working with VLC. Does anybody have a solution
Old 11-16-2008   #2 (permalink)
Vista Ultimate 64bit SP2/
Re: wmv problem
Hello and welcome to the forums,
What is the error that comes up when you try to play wmv.
Old 11-16-2008   #3 (permalink)
Re: wmv problem
This is the error message that i get:
You've encountered error message C00D11B1 while using Windows Media Player. The following information might help you troubleshoot the issue.
Old 11-16-2008   #4 (permalink)
Re: wmv problem
Try downloading this
|MG| Vista Codec Package 5.02 Final
If that doesn't work make sure these are checked.
Old 11-16-2008   #5 (permalink)
Re: wmv problem
I have downloaded Vista Codec Package and also checked the privacy settings i still have the same problem. By the way, I forgot to mention that, when i try to play some avi files media player stops working.
Any help?
Quote  Quote: Originally Posted by mansrm81 View Post
Old 11-19-2008   #6 (permalink)
Re: wmv problem
Not anyone?
the problem with ndis.sys Blue Screen of Death problem solved? Vista General
Re: Windows Mail Attachement Problem and Adobe Player Problem with IE8 Vista mail
Multi-select problem in Windows Explorer BIG PROBLEM!!!!!! Vista General
Generic McAfee Problem Message in Vista Problem Reports Vista performance & maintenance
Vista Upgrade Problem - Windows Explorer Loop problem Vista installation & setup
