| Newbie | Media Center will not run after reinstall Okay I basically have the same problem. My hard drive crashed and I had to install a new one, reinstalled Windows Vista, but Media Centre is nowhere to be found. Searched for %SystemRoot%\ehome\ehshell.exe as barman58 suggested. However, the following error message pops up "Windows cannot open this program because it has been prevented by a software restriction policy. Contact your system administrator." |
| Antidisestablishmentarian | Re: Media Centre Missing. Hi, Vortex81, and welcome to the forums. I am moving your topic off to a new topic as your issue is not quite the same as the one you responded to. Now, can you detail the process by which you 'reinstalled Vista' on your machine? Also, machine specifications would be helpful, such as if this is a home built machine or a machine purchased from an OEM, etc... |
| Newbie | Re: Media Center will not run after reinstall I had to reboot the machine. It's a Dell 1525 Inspiron 32-bit OS |
| Newbie | Re: Media Center will not run after reinstall Sorted. control panel- default program - set access and computer defaults - custom - choose a default media player. Clicked Windows Media Centre The Icon then appeared in the start list. |
| Antidisestablishmentarian | Re: Media Center will not run after reinstall Glad ya got it fixed. |
| | #6 (permalink) |
| Newbie | Re: Media Center will not run after reinstall Great post..it worked. Been searching for a fix for this same issue for a long while. Thanks man |
| | #7 (permalink) |
| Banned | Re: Media Center will not run after reinstall That how I am I think of the most simple answer and usually it works.If not ask a pro here Nice avatar BTW johngalt |
| media center visualizations don't play in Media Center | Media Center | |||
| Reinstall Windows Media Center | Vista General | |||
| Media Center 2005 to Vista Media Center Compatibility | Vista General | |||
| Windows Media Center How to make aux input show up in media center | Vista music pictures video | |||
| Reinstall Media center only not OS | Vista General | |||
