Go Back   Vista Forums > Vista Forums > Media Center
Vista - What format to rip dvds?
Old 01-01-2009   #1 (permalink)
Vista 32bit
Hi all!
I have a large collection of DVDs that I want to rip onto my computer and play under media center. I am using the program 'DVD Decrypter' to rip them but every format that I have tried does not show up in MC when i go to 'view dvd collection' even though i have added the correct folders for it to search under.
What format should i use or is there another setting i need to change?
Old 01-14-2009   #2 (permalink)
Vista Ultimate x64
Re: What format to rip dvds?
For Media Center to detect the movies rip them as a DVD (it will create TS_Video & TS_Audio folders). Then make the following registry change: HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Media Center\Settings\DvdSettings and change the "ShowGallery" value to "Gallery."
Now your movies will show up under DVD Library
-f format Format-Table Format-List against Select PowerShell
Windows Mail format bar doesn't format color, size, justification Browsers & Mail
Unable to format DVD-R after burning several DVDs Vista General
Ignores BR/DVDs or DVDs but CDs works fine. Vista hardware & devices
Are volume licensing upgrade DVDs bootable?--they do not ship full DVDs. Vista General
