Missing guide listings for 2nd HD channel 18-2 KLRU Create
  1. #1
    Newbie
    Vista Ultimate 32bit
    Local Time: 04:41 AM
    The local PBS station here in Austin has a second HDTV station channel 18-2 KLRU Create. The programming is your standard how-to PBS stuff like New Yankee Workshop, Central Texas Gardner, Make, et cetera. However, when I add the channel and go to select the guide listings, they are not available. I can find KLRU's main station channel 18-1, but Create seems to be whole absent from available choices. I can only surmise that this means that the guide listings are not making it to the guide listings provider. Sure, I could go in and manually add recording times and the channel, but that's not going to work for keywords or program names.
    How does one go about filing a request to get these guide listings added???
  2. #2
    Newbie
      Thread Starter
    Re: Missing guide listings for 2nd HD channel 18-2 KLRU Create
    Anybody have any idea which source the guide listings come from? I thought it was zaptoit.com, but checking there, the KLRU2 / 18-2 channel is listed and has the data. I just have no idea whom to rattle to get it fixed. Grrrr!
Missing guide listings for 2nd HD channel 18-2 KLRU Create problems?
Can't search guide listings to record a show Pbb321 Media Center 0 09 Feb 2009
Guide listings not available for Australia! Help! Tristan-117 Media Center 0 22 Dec 2008
Vusta Media Center Guide shows wrong channel lineup podolj Vista General 2 28 Jul 2008
Media Center remote/guide won't change Cable channel zod Vista General 0 09 Sep 2007
Media Center has started to fail to update Guide listings Frederick C. Wilt Vista installation & setup 3 08 Sep 2007
