| Windows 7 Ultimate 32Bit (Build 7600) | Upgrade to 64 Bit - Benefits? I have an established movies setup across HD TV, NAS devices and 2 PC's, with a similar setup as my system spec. My questions are:
| Vista business x64 | Re: Upgrade to 64 Bit - Benefits? There are 2 'main' differences between 32bit and 64bit namely: -64bit allows for more than 2gb to be effectively used for a SINGLE application. No game or video playback software at the moment would ever need more than 2gb of memory though. -64bit enabled CPU's are able to process MORE commands at the same time (twice as many in fact) however there are hardly any programs/applications out there that can actually make use of this. I don't want to go into too much detail because frankly its unnecessary and I don't know all that much about it to begin with but I can tell you that your games or video playback software will hardly (if at all) be able to make use of this extra processing power. At the moment the critics are agreed that 64bit is only usefull for high-load operations such as video/audio editing which eats up loads of CPU and RAM, servers, scientific research computers and distributed computing (such as BIONC enabled stuff). conclusion: NO, you will most definatelly not get any noticable/worthwile improvement or increased stability. |
| Win7x64 | Re: Upgrade to 64 Bit - Benefits? -64bit enabled CPU's are able to process MORE commands at the same time (twice as many in fact) however there are hardly any programs/applications out there that can actually make use of this. I don't want to go into too much detail because frankly its unnecessary and I don't know all that much about it to begin with but I can tell you that your games or video playback software will hardly (if at all) be able to make use of this extra processing power. As for whether games and other software "will hardly (if at all) be able to make use of this extra processing power", you've probably heard of Moore's Law: "The hardware horsepower of a typical processor will continue to double roughly every 18 months". There's an equally accurate though far less well known corollary: "But it doesn't matter because the software will always p##s away all those hardware gains, and then some" |
| Vista Ultimate x64 sp2, Solaris x64 | Re: Upgrade to 64 Bit - Benefits? Vista 64bit is more secure, faster and stable, no doubt about it. cheers... |
| Windows 7 Ultimate 32Bit (Build 7600) | Re: Upgrade to 64 Bit - Benefits? -64bit enabled CPU's are able to process MORE commands at the same time (twice as many in fact) however there are hardly any programs/applications out there that can actually make use of this. I don't want to go into too much detail because frankly its unnecessary and I don't know all that much about it to begin with but I can tell you that your games or video playback software will hardly (if at all) be able to make use of this extra processing power. As for whether games and other software "will hardly (if at all) be able to make use of this extra processing power", you've probably heard of Moore's Law: "The hardware horsepower of a typical processor will continue to double roughly every 18 months". There's an equally accurate though far less well known corollary: "But it doesn't matter because the software will always p##s away all those hardware gains, and then some" ![]() Thanks for the replies and you back up what I thought that the benefits don't justify the re-build time. It's strange that few people can justify moving to 64bit and yet the majority of system specs indicate a 64 bit install!! lol ![]() UKMedia |
| | #6 (permalink) |
| Vista Ultimate x64 SP1 | Re: Upgrade to 64 Bit - Benefits? Thread is a bit over but you might find this in interesting. 64-bit: More than just the RAM Really? Photoshop easily uses 3-4 GB of my RAM and GTA IV is happy to eat away 2 GB of RAM (patched 1.3 so no memory leak). Last edited by mattinahat; 04-23-2009 at 02:03 AM.. |
| | #7 (permalink) |
| Microsoft® Windows Vista™ Ultimate x64 SP2 Windows 7 7127 x64 | Re: Upgrade to 64 Bit - Benefits? One of the best operating systems around |
| Microsoft trims MVP benefits, allows shareholders say on executives' pay. | Vista News | |||
| oc benefits | Overclocking & Cooling | |||
| Benefits of VISTA Ultimate x64 vs x32? | General Discussion | |||
| Vista Benefits? | Vista General | |||
| Deeper benefits | Vista General | |||
