| 32bit | Moving Problem i have a 4G pen (flash) drive and when i try to move song from the computer, or even when i tried straight from my mp3 player it says Error: file is no longer located in (location) please verify location and try again. i can move files to my mp3 but not that specific drive, how do i fix this? |
| Vista | Re: Moving Problem Did you perhaps change the name of the folder? That might be the problem. If your song is indexed at a certain location, but you changed the folder name, it still looks for that previous location. Cheers, |
| vista 64x | Re: Moving Problem yea, you can try to first copy the songs onto a seperate folder in your computer, then transer it to you mp3 that might help |
| Problem moving folders | Vista file management | |||
| Moving folder problem!! | Vista General | |||
| Problem moving messages | Live Mail | |||
| Problem moving folders - this is a bug! | Vista file management | |||
| Problem moving folder from one drive to another | PowerShell | |||
