Go Back   Vista Forums > Vista Forums > Media Center
Vista - problem: repetitive startup
Old 05-13-2009   #1 (permalink)
Vista Home Premium 64 bit
Hello, I am having a problem with media center. It repetitively starts up while im using other programs and also when I am not. It almost makes me think I have a virus that only causes media player to start up. I would like to remove media player from my computer but I hear this is not possible.
My specs are:
Intel Core Quad Q8200 @ 2.33 GHz
Windows Home Premium 64 bit
NVIDIA GeForce GT 120
avast! Antivirus 4.8 home edition
Media Center simply starts up and the second I click the X to end the program it pops right back up again. Sometimes it waits awhile before it pops back up and sometimes it happens immediately. Sometimes it starts while my computer is just sitting idle and not being used. I dont want media center and I want to get it off my computer if anyone has some suggestions Id greatly appreciate it.
Old 05-13-2009   #2 (permalink)
Windows 7 Ultimate x64 (Bata) & Windows Vista Ultimate x64 Sp2 & Windows XP Professional x32 Sp3
Re: problem: repetitive startup
I'm not any help but wanted you to know your not the only one that's happened to.
Mine did that exact same thing a wile back and I said screw it and reformatted.
So like I said not any help but your not alone!
Old 05-14-2009   #3 (permalink)
Well, I unplugged my logitech G15 keyboard and the problems went away. Hope this maybe helps someone in the future. headed to the logitech site...
Old 05-15-2009   #4 (permalink)
Vista Home Premium 64bit
I'm having the same problem, and I understand many other are as well. So, is there a solution? I have a laptop and sure cant unplug my keyboard or would want to anyway to solve this problem. I've read on some other sites that windows is working on this problem, it may be a registry issue, and something about 64bit processors yada yada. Gateway (my computer manufacturer) tells me they don’t have support for 22 character S/N laptops. So...seems hopeless. Thought about calling windows myself, but after reading about a $59.99 tech support charge, I said forget that! Please! Is there anyone out there that can help this issue? Its extremely annoying and aggravating. Thank You.
[problem] problem signagure = startup repair V2 General Discussion
Startup Problem Vista General
Receiving error. inbox has a message stuck producing repetitive emails. Vista mail
windows vista calendar repetitive tasks Vista General
Repetitive Media Player run.dll degrade Vista General
