| Ashley | TV tuner not detecting channels :( Hi I recently bought a TV tuner (Compro VideoMate Vista E700) for my computer. I attached the card to the motherboard and the power supply fine and the computer turned on without any problems. I then installed the software and the drivers, again, without any problems. When I scan for channels via the software it detects not channels. It is plugged into an aerial which works because the aerial use to work with a digital TV. Just wodering what else I could do or change to get it to detect channels? Any help would be much appreciated Thanks |
| TV Tuner Not Adding Channels | General Discussion | |||
| MCE wont find channels when my OTA tuner is part of the tuners, why? Can I manually.. | Vista hardware & devices | |||
| Using a Hauppauge 1250 tuner card - I get channels w/WinTV app but not w/Media Center | Media Center | |||
| How can I add tv channels ? | Media Center | |||
| VMC Tuner only picks up BBC channels | Media Center | |||
